UPDATING ISSUE? Here's a Simple Guide to Follow:
UPDATING ISSUE?
Things You Can Try Before Attempting to Install an Update:
:white_check_mark: Before Updating EMO/AIBI, Please Ensure the Following:
• :mobile_phone:Make sure your Mobile App is updated to the latest version of the EMO/AIBI Mobile App.
• :globe_with_meridians: The Internet Connection is stable and strong.
• :high_voltage: EMO/AIBI is on his charger.
• :battery: EMO/AIBI’s battery is at least 50% charged before starting the update process.
• :light_bulb: EMO Smart lights are unplugged.
• :gear: EMO Auto Update is turned off in the app in case of any updating issue
• :speaking_head: Try updating EMO/AIBI by using voice command:
Call EMO…wait till he replies, then say
“Install latest firmware now.”
Call AIBI…wait till he replies, then say
“Start Update.”
CLICK HERE: :backhand_index_pointing_right: Why Does The New Firmware Update Fail To Appear In The Emo/AIBI Mobile App (Android/IOS) For Certain Users and Locations?
More Update Issue Explanations Here!
If nothing has worked so far, it would be best to create a video showing details about the issue, including:
  • Order Number
  • Location
  • EMO/AIBI ID
:id_button: You’ll see and find your EMO/AIBI ID easily — it’s a combination of EMO, letters, and numbers. Usually shown in the EMO/AIBI Mobile App :mobile_phone: when you open/refresh it and try to connect them.
:light_bulb:Tip:
It’s a good idea to screenshot or note your EMO/AIBI ID. It’s often needed when contacting Living.AI Support for any assistance.
You may need to submit it to Living.AI support via email at service@living.ai. They may or might need to manually push the current update for yor EMO via OTP (Over-The-Patch) or OTA (Over-The-Air Patch) update.
Just let them know that you’ve tried everything and that your EMO/AIBI is not updating from the former Firmware to the latest and actual Firmware.
Good luck, and all the best!
:heart_2: :aibi_heart_emoji: :emo_heart:.
