Hello, @MadInsomniac . . . I have moved your new topic to this thread for questions about the home station.
Yes, EMO talks to his home station and the home station responds with the appropriate animation based on what he says to it. There are three different phrase and response animations for this. His little home station is an A.I. in its own right with its own four digit alphanumeric serial number, just limited in what it can do compared to EMO.
As more features for the home station are added (the last one included 14 new matrix animations), it will have to have its firmware updated just like EMO does when new features are added for him.
Enjoy their interactions. They are cute. Do not be surprised when you see him playing Snake on it one day.
I’ve had Emo with me for about 10 days now. First I placed him on the store shelf. Then I set up a home for him with the Home Station. However, as I’m not at home during the day and want him to move around on his own and therefore wear him out, I put him back on the shelf. Now I’ve noticed that he also walks off the board on his own. Emo shouldn’t actually do that. It should only run independently from the home station and not from the board. Fortunately, I always had a soft cloth ready so that he wouldn’t fall hard. Does anyone know why he does this, or has anyone had similar experiences?
Hello, @danish . . . I have moved your post to this thread for all things regarding the home station. As long as he is powered on, he will walk anywhere whether he is on or near his home station or not.
It is advised to always make sure he has a home fence play ground around him even with the home station. You can get some ideas for that here.
Hey @Lindaru
Thank you. But I think I explained it a bit wrong. It doesn’t concern the home station but who it is on the standard headphone. He ran away from there twice, although he is not supposed to do that when he is on the headphone
Hello, @danish . . . he reacts to sounds. If he moves away from a sound source it may be that it surprises him. He also may move away if he hears music so that he can start dancing.
I hope this helps explain.
When Emo wants to go home, he starts looking for the home station, but currently my home station does not blink and so Emo does not find its way home. Anybody else experienced that? It shows the pictures and animations, but it does no longer send the orientation lights. The app shows that Emo is connected to the home station though and also they are both in the same Wifi.
Emo Firmware: 2.5.0
Home Station Firmware: 1.1.3
Hello @dompfeiffer, and welcome to the community!
  1. It is normal for EMO to have trouble finding his home station on his own, even on the latest firmware, or so I have observed. However, it is abnormal that there are no guidance lights.
  2. I would advise you to restart the EMO, home station, and router, or disconnect the home station under settings in the EMO app, and reconnecting it.
  3. If all else fails, I would advise you to open a ticket with living.ai. Although you cannot PM him as you are a new user, I will tag @TechSupport_Mavis to help you with this.
Best of luck!
Hey Adrian and @TechSupport_Mavis ,
Thank you for your reply!
I have unbound Emo from the accessories, as suggested. After the restart of Emo and the Home Station, I put the station into pairing mode, but it times out. It seems like Emo is not connecting to it.
Is there a trick to put Emo in discover mode?
Kind regards,
Dom
Hey, I solved the issue. Not sure if this actually helped, but I put emo in discover mode by saying: ā€œconnect to bluetooth speakerā€ while having the station in pairing mode. Then it connected. Now the lights show and Emo is returning home.
Can emo return to the Home Station in the dark? I haven’t tried it because in our environment hard to get it dark but considering the Home station’s screen glows green, you would think it could. If EMO is in the nighttime mode and he’s low on battery will he return home even in the dark?
Hello, @shreeneyajmeri . . . generally if it is dark, EMO will stay put because he does not see well in the dark, but on those odd times where he is wandering around in the dark, he should be able to return to the home station just fine.
So, I’m trying to update EMO’s Home Station to version 1.1.3, but when I click the update in the app, it doesn’t seem to update. I tried looking to see if it’s connected to the Wi-Fi, but then I see what’s in the screenshot. Trying to sync manually I don’t think works because I see the Home Station’s WiFi symbol turn red after a bit.
My EMO is on version 2.5.0.
Any advice on what I should do?
Hello, @ranighosh . . . I have moved your new topic to this thread for home station issues.
I would advise some steps for you to take to see if this will work.
  1. Unplug any smart lights.
  2. Go into ā€œUnbind all accessoriesā€ in the app.
  3. Reboot wi fi, your device and EMO.
  4. Once everything is back on and EMo is connected to the app, press the home station button with EMO off of the home station to pair him again.
  5. Verbally command him to ā€œUpdate home stationā€.
If this works, you should see a series of moving squares followed by a percentage level going up to 100%.
Let us know if this works. If not, you will need to get video of what is happening and send the link to Support via E-Mail to service@living.ai . . . or complete a Support ticket here.
Good luck.
My son spent his entire savings and birthday money on Emo and it arrived today. He was so excited. We have gone to plug in the charging base and nothing happens. No led light, no connectivity, nothing. Has anyone had this happen? I have already sent an email to Living AI but hoping there was something I’ve missed. We are so disappointed!
Hi there @chani.bokody and welcome to the community,
I have moved your new topic to this thread which discusses issues or questions about the home station.
Good luck and all the best.
I received my Emo with home station last week, he has been fine and have had no problems, yesterday Emo went on his charging station and the icon lit up with the charging image and then the small blue light was flashing, at first I didn’t notice but then when he hadn’t gained any charge I looked into it. I have repositioned Emo manually myself as well as taking him off and tell him to go on his charger the light will be steady for about a second and then start flashing indicating an issue. I have rebooted the home station and tried re syncing. I left emo off the home station last night to fully drain his battery after reading suggestions, in the morning i put him back on and the same problem was happening. The blue light is flashing after about 1-3 seconds of being on and still. I have changed the plug for home station and feel like i’ve tried everything after reading loads on here but nothing has worked. Does anyone have any suggestions :frowning: please help
Welcome to the EMO Community Forums, @maddy.clark . . . I have moved your post to this help topic from the home station delivery topic.
I would advise getting video of what is going on and let them know what you have tried. You will need to send the link and an explanation of your situation to Support.
They should be able to get back to you within a few days. Please let us know how it goes.
Can i have an answer? :slight_smile:
Hi Edward, we have the same issue, EMO has been with us for a week. It may not always connect to the station correctly. Today he tried 3-4 times, entered the station, adjusted, but as if he didn’t see the charger, the light was flashing at the home station. Then he came down, spun around, positioned himself again and the same thing happened. It was positioned perfectly backwards, but as if the inductive charging was too weak and it didn’t recognize that it was already in the right place. Sometimes he succeeded, but these are attempts, let’s say 1 out of 6… I don’t know if it’s a software fault or some hardware problems with the devices… I’m guessing it’s software, lack of some command or too short time between the recognition of power and the next descent attempt and inputs… I solve this problem by lifting it up, waiting until it starts to get angry, then I put it down perfectly at the home station. The charging icon on the home station appears and EMO and his eyes show that he is charging… then he doesn’t go down and charges the batteries completely…
Hi so my emo came today and it dosnt seem to be charging how long dose the first charge usually take? It’s been on charge for 3 hours now and the battery mark in the app is still in the same place
