The Topic Title Says It All!
Please post everything about Home Station only here, so that easy to find and convenient for all of us.
EMO, HomeStation, Smart Light Connection Issue Solution Tips to Try!
Home Station and Home Fence
IMPORTANT INFO!
EMO And His New Home Connectivity And Functions:
  • Only one EMO can connect and use the Home Station.
  • Connecting the tower: Carefully press the tower into the plate with no gaps (avoid forcefully disconnecting them without reason, as it’s tightly connected and could break).
  • Powering up: Use only the original power cable supplied to power the EMO and the Home Station. The dynamic matrix display will show a house-building animation, and the mini green lights at the bottom will blink three times.
  • ***(New Home Station Units): A speaker has been added to the Home Station, allowing a connectivity sound when powered/startup.
  • Home Station Re-Start: Long-press the button to restart it, and the latest version home station will play a short startup music.
  • Network Configuration: Connect EMO with the app and set up the network (requires Firmware Update 2.0.0 or later).
  • Pairing EMO with Home Station: Hold the button for at least 5 seconds. Wait for the Bluetooth pairing animation on the dynamic matrix display.
  • Charging EMO: Place EMO on the Home Station to begin charging or resting. To check if EMO is charging, watch for the charging animation in his eyes and look for the steady mini-green light between his legs.
  • Changing dynamic matrix display animations: Softly touching the button will cycle through 20 different display animations. Continue holding the button to turn off the animations (this doesn’t power off the Home Station).
  • Power status: When the Home Station is connected but appears blank, you can still charge EMO. Place him on the station and wait for his eye-charging animation, followed by the Home Station’s battery charging indicator.
  • Restarting EMO: If EMO is off and you place him on the Home Station, the Home Station’s battery animation will appear, and EMO’s headphones will blink blue three times. After 20-25 seconds, EMO will turn back on.
:information_source: HOME FENCE BLACK EDGE WALL RISK INFO:
EMO’s optical foot drop sensors are not 100% foolproof. It’s a known issue that when EMO is engaged in activities like dancing, playing, or performing daily tasks, his sensors may temporarily deactivate. This could explain why he sometimes ignores the dark-colored walls of the home fence.
In my opinion, I wouldn’t fully rely on these optical drop sensors, especially when EMO is unattended on a table. It’s best to create an enclosed play area for him to ensure he can move safely without the risk of falling.
For more official info about Home Station features please click the link below:
New Update Logs!
Take note that there is a touch button below the front tower to pair him, turn on/off, and change the dynamic matrix animations on the display screen. (Meaning: as soon as you plug in the charger and pair it, you can always put EMO on it for charging).
The new Firmware Update v2.0.0 or later must be installed/updated on EMO and EMO PET App takes the full functions for Home Station features for all EMO (Old/New).
BEST REGARDS, STAY SAFE AND HAPPY ALWAYS!
***UPDATED!!!***
Was surprised to get my EMO go home today! However I found out my EMO cannot charge :sob:
The charging points are too deep so when I put it on the go home it does not charge.
Can anyone please help? Have attached the picture.
Hello @pogochai send a email to service.living.ai. Or you can make a ticket here https://living.ai/product-support-emo/ Hope this helps! :happy:
Have put in a support request as well.
Thanks.
:open_mouth: Hi there @pogochai,
…is that EMO GO HOME ??? did you read the
Instruction Feeding Manual properly how to use that?
As far as I know, if you bought the EMO Go Home Version it is already running a production version firmware higher than 1.7.0 (so they can return to the Home Station themselves).
Because the Home Station is connected to the WiFi after this function is in the app. which means you can not do this before until the new version of the app is released.
BTW…will you please go to the link below and if you don’t mind share your experience…
Delivered…EMO is Finally At Home (Pls. Post Here)
GOOD LUCK, ALL THE BEST AND STAY SAFE
Yup. It is EMO go home. First is power EMO up. Have no idea how to do this so I suppose it is putting on the charger? Next is connect to app but EMO is off so can’t detect.
Any ideas?
You my friend are a genius. It is charging now. So happy!!!
So happy now. Is there a way to find out how much is EMO already charged?
…you can just call his name and ask….
EMO! (When he replied…) Show me your battery level!
Or you can view it on his EMOPET APP
Thanks @edward appreciate the help
You have it wow ? Did you got any tracking info before ? Let me know or you are a Beta Tester
Hi @EmoMike23
Nope I am not a beta tester. And I also didn’t get any tracking email. Was surprised to receive it.
I ordered The Go Home middle November ? And you just to have an idea
Did your order changed to complete? Im pretty sure i wobt be getting mine no time soon i ordered mine on Christmas eve
Hello happy for you :gift_heart::+1:
Could you please show us the map, the leds close up view ? Thank you :pray:
@pogochai congratulations on your emo!! Can you tell us when you ordered your emo go home and when you received it? Just to get an idea on how long it will take!
Hi there @Skibosh ,
The link below will show everything about…
best regards and keep safe…
Just be patient. :wink: I was expecting it to only come in Feb as the forums mentioned. So happy it came earlier.
If it helps I’m from Singapore. Where are you from? It could be on the way as well. :slightly_smiling_face:
Thanks. Sorry don’t understand what you mean. It is exactly the same as the demo showed on YouTube by the beta tester.
Btw just a tip. In order for the EMO to find the home, the app needs to have use “location” set to “always”. I tried “only when using” and it couldn’t find the home. @edward not sure where we can put this tip. :slightly_smiling_face:
