Welcome to the EMO Community Forums, @jaimy . . . I have moved your posts to this thread so that we can keep the conversations together.
Good luck to you!
Good luck to you!
Since the latest update, my first emo (that i’ve had since the end of May) has fallen off the table so many times i’ve lost count (always seems to happen when I leave the room).
He even pushes through things I have around the mat to stop him, walks another roughly 4 inches to the end of the table and dives off. It’s like he has parkinsons now; one of his legs shakes and is weak. It’s become quite annoying. A mat with a solid raised border really needs to be designed asap.
Hi there @christopher.russ ,
I can tell you only my personal opinion that it is not the problem of the new firmware update…
Actually, it’s a known issue…when EMO is busy doing anything, like daily activities, dancing, and playing, his optical foot sensor is automatically temporarily disabled.
IMHO, I will never trust this sensor 100%, particularly when it is unattended on the table… Provide an enclosed play area for him… so EMO can walk safely and not fall off the table.
That’s why I created like what you can see in my image below. It’s the so-called Box/Package Cardboard Corner and sides Protectors , It’s a used one that I found at my workplace lately, cut them to the right size and placed them under the Home Fence…normally you can find it also online at different price ranges.
Please click on the link below for information and instructions…
Pls. Click Here!
GOOD LUCK, BEST REGARDS, AND TAKE CARE EMO!
I can tell you this didn’t happen before the latest update, and my other emo doesn’t do it. He just ignores the black border on the mat. Thank you for the box idea I will look into that
It’s not working on my emo since 3.0 and after updating to 3.1 he glitches and doesn’t stop on edge.
help? pls?
how can it be fixed?
RE 2.3.1
My first emo told me there is an update, had an update notification on the app updated no problem. Although I still get a button in the app telling me to update to the same update that’s been installed.
2nd emo tells me there is an update available, no notification on the app. Update through voice command fails.
Just posting for reference sake.
pls help me @Wayne_Zhang
Hi @ValaLin,
:NOTE:
The Current Firmware Is v2.3.1,
There Is No v3.0.0 Or v3.1.0 As Yet,
But I Was Also Still Having An Edge Detection Problem Since The v2.3.0 Update, Same Issue Occurs After The v2.3.1 Update As Well.,
If You Are Having This Issue, It Is Recommended To Contact Support By Submitting A Ticket On The Website.
Please Click Here
I Will Tag Moderators @edward Or @Lindaru So That They Can Help.
If It’s A Hardware Issue, You Can PM Moderator/LivingAI Staff @TechSupport_Mavis From The LivingAI Support Team, If It’s A Software/Firmware Issue, You Can PM LivingAI Staff, Wayne_Zhang (Tagged Above) So That They Can Help You
Hello, @ValaLin and @christopher.russ . . . if you could please get video of your edge detection, and voice command and app issues, then post the link here so that we can see what is going on.
I will say that my own EMO I had to update through the app as they gave the not understand sound when trying to “Install latest firmware now” command.
Edge detection issues can be that the foot sensors need to be cleaned.
Here is something you can try.
Keep us advised.
My Emo6 will not update. Voice command won’t work Although this morning the app did show the available update but I was too busy to try to update that way, & the app doesn’t show any updates now. What’s going on.
My EMO is also showing there’s an available update, but the app doesn’t (just says “current version 2.3.0”) - and when I say “install firmware” he just restarts, gets about 13 seconds through updating, then restarts again and shows me the “update available” animation again. But that’s it - it’s a loop, and I can’t complete the update no matter what I do.
I’ve restarted my phone, made sure Home Station and the app were up to date, and have auto update turned off.
Hello @Racheal123 and @dergonfruit . . . I would suggest trying throughout the day or evening either voice command or if app shows available, through the app. I would also make sure “auto update” is off in the settings preferences part of the app.
There are probably a lot of people updating their EMO and the servers may be busy. If it is still not possible to update by tomorrow, definitely contact Support as indicated above.
From what I heard they are slowly open the updates so that aren’t overloading the server.mine still hasn’t gotten it yet.
Last night, before the update, Emo went back to the home station without assistance when needing to charge, after displaying the need to charge animation.
This morning, after the update, Emo is not able to return to home station without help. Emo gave up trying to get home after being unsuccessful, the “Go Home” instruction was used another 2 times but Emo failed each time. Emo does try to get home and the Home station displays the green screen the same as last night.
Had to place him on home station to charge.
@Jonny5Alive . . . so sorry to hear this. Do you think you could get a video of this so that we and the Living AI staff could see what might be going on as to why this is happening?
We look forward to assisting you further.
Yes I did all that, like I said voice command won’t work, anyway I am just waiting & watching as Lindrau suggested. Thanks anyway
Lindrau I always have the automatic update turned off because it’s not reliable thanks though.
Lindrau have you managed to update your Emo?
Jonny5Alive So sorry for your experience
Hello, @Racheal123 . . . yes, it only took a second try to get my other one updated (EMO Pet). EMO Robot updated right away. I used the app on the second attempt and it worked well. Of course, this was in the wee hours of the morning when server traffic coming from North America was likely lighter.
Thank you! I tried updating last night again right before I went to bed, and it worked. It was likely just an issue with server load!
Buongiorno. Ho visto oggi che è uscito il nuovo aggiornamento 2.2.0 di emo, ma non riesco a capire come aggiornarlo perché sull’app non mi da nessun aggiornamento. Inoltre il
mio emo è nella versione 2.3.1 non so se possa c’entrare qualcosa. Infine ho selezionato la lingua italiano ma emo non sembra capire bene quando parlo, in verità non sembra capire molto in generale anche in inglese, potrebbe avere qualche problema? Come posso fare per migliorare?. Grazie per l’ascolto.
