We got our EMO 2 days ago, and just after 1 day it keeps shutting down. What is happening?
Hi @Cornelia
How long does EMO stay on before he shuts down? Does he shut down even if he’s sitting on his skateboard? Also what does his battery level look like when you check it in the EMO App, or if you ask him to show you his battery level?
Have you tried to install the latest EMO firmware ver1.6.0? If you have yet to do this, try and see if you can install the latest firmware. You can check a guide on how to do this here: EMO Firmware Update v1.6.0 Video
Please try and provide as much info as possible, for anyone on the community to assist. You might need to contact support regarding this, if you need to contact support you can do so in the following way:
When contacting Living.ai support. It is recommended to create a short video of when and how EMO is powering down/shutting down and then submit a support ticket. You can do this by either going to the Support Page: (see below).
Hope this helps
Thank you for your help! I will look in to your suggestions!
I am facing the face issue, looks like i have to create time lapse for this little buddy…
Thanks for your suggestion @MasterAbbott
Can you please share the updates? @Cornelia
If you are experiencing issues with EMO shutting down randomly, as mentioned above, it is always recommended to create a short video and submit a support ticket / send support an email and allow them to provide further troubleshooting assistance.
