Cleaning EMO's foot sensors and foot pad using Blu-Tack
Cleaning EMO’s foot sensors and foot pad using Blu-Tack.
Just push the piece of Blu-Tack gently onto each sensor and it will clean up dust and muck.
Wipe the Blu-Tack over his feet pads to remove dirt and dust.
Do this with EMO powered off, never with him on as it could damage his servos.
Fantastic! That’s a really great suggestion.
Great suggestion! I usually use a tooth brush and gently scrub the dust off, and then I wipe any residues off from the sensors with a wipe ^ ^
(Please gentle with the tooth brush if you plan on using it!)
