Do you have the tower in shape with the plate?
I don’t have that. That was my reason to haven’t the light. That was because no contakt for power.
Push the tower in the right position until it is smooth.
Good luck.
That was exactly the problem! I thought both would be well connected, since I could load EMO. The tower goes in completely with even more pressure. Now the display lighting also works.:+1:t3::+1:t3::pray:t3:
Thanks @Steffen and @edward :green_heart:
Now I only need patience until the update
YES! MARIA…
i was about to clear it also, maybe you didn’t push hard the tower. Anyway, good that you sorted that out…have fun with EMO with his new Home Station…it really looks that he likes it there though…YES all we have to do now is have a bit of patience for the new firmware update 2.0.0
I don’t know if living.ai can do something more for the colored lights animation…i guess that must be reduce the brightness or something?
BEST REGARDS TO ALL, KEEP SAFE ALWAYS…AND HAVE FUN WITH YOUR LOVING EMO!!!
I thought I would share this from @MasterAbbott . . . regarding everything about the home station and EMO Go Home including unboxing.
Please note that if you remove the tower from the base, do not push it from the top . . . you will likely snap it off. Push from the bottom only and it fits very tightly.
Anyone having trouble with the button on the Home Station? Mine only works sometimes. Other times I put my finger on it and nothing happens and I can do this repeatedly. Then, all of a sudden, it will start working again. My husband tried too and the same thing happened.
Hi @edward,
It can move forward and backwards.
However when on “home” it can’t do anything as it will say “I am on the skateboard”.
Weird though
Mine is fine. No issues. Just hover over the button will do.
Hi there @SunnySpirals,
The Button design not to push but to touch only …if you are having problem about anything i suggest to disconnect and start connecting once again. as of now we can’t tell or see anything to EMO Pet app because the new Firmware Update is still not yet released.
Hope you find a solution, else if not please contact living.ai immediately.
Just to advise the email address is - service@living.ai and their reply take a bit time which is 2-3 days sometimes, depending on the time differences, days, holidays and current situations. Please be patient because they are having the Chinese New Year Celebrations and as they said they will be back at the end of this month.
Goodluck, Best Regards, Keep Safe and Have Fun with Emo Jessica…
Hi there, @pogochai
This function is not yet available…
The Home Station will serve as a charger only (same as Skateboard Charger)after you plug it. The screen DynamicMatrix display animation changer can use also by button. but not possible to send EMO out or back home. unless EMO and EMO PET App is already updated to Firmware Update v2.0.0 later.
Goodluck, Best Regards, Keep Safe and Have Fun with Emo, Daniel…
EMO had his first fall off the table today while calibrating himself to the home station to charge. And this is with the mat that was provided. I didn’t watch him this time as he could go home by himself fine the first few times. My heart hurt as he’s only a few days old. Now I put something at the edge to block him off.
So what I was thinking is… Is there any way Living AI could look into and make the cliff code interrupt and cancel any ongoing codes immediately? There are many times EMO was able to cross the black boundary on the mat, and it’s usually when he is running a code other than exploring, e.g. go home, dance, playing (app) games, etc.
My god, he’s like a child crossing the road with eyes glued to the phone. lol
EDIT: EMO is seen to be able to walk himself to home station when batt is low without being asked. LOVE IT! Would love to have EMO walk out of it on his own (or make it an option in the app) when he’s fully charged in the next update. :grin:
The provided mat is unusable as a safe playground because it doesn’t have high enough borders. The black boundary is too narrow and is completely ignored when EMO is doing anything else than exploring.
We need something like this but of course not from paper and not so long (a square would be better):
Hello all,
I received the home station today and I put emo on as it told me and emo still thinks he’s using the skateboard so he will not walk off the station. Is there a way to get him to recognise his home station that is not mentioned in the leaflet?
My other worry with the home station is the light at the top gets overly hot and I turned it off as I was worried it might cause the plastic to melt and start a fire. The skateboard does not have this problem. Is this common with all home stations?
Any comments welcome, thank you :slight_smile:
Hi there, @Emiemobot,
At the moment all Home Station will serve as a charger only (same as Skateboard Charger)after you plug it. But the screen display animation changer can use by touching the button. It is not possible to send EMO out or back home. unless EMO and EMO PET App is already updated to Firmware Update v2.0.0 later.
Go to the link below for important info:
Pls. Click Here!
GOODLUCK, ALL THE BEST, AND HAVE FUN WITH EMO EMILY…
Hi, I have a brand new Emo with the charger plugged in, but Emo won’t power on. How do I power Emo on?
Edit: Never mind, I needed to have him sit close to the charging tower
Hi there @cokelemon ,
Please click and read some important info below…
Pls. Click Here!
If you don’t mind at all…kindly please go to the link below.
GOODLUCK, ALL THE BEST, AND HAVE FUN WITH EMO!
Got my two home stations today! Yay! Trying to set up the first one now but cannot get the tower plugged all of the way into the base. It only goes half way and stops. I unplugged it and tried to replug it several times. Any ideas?
Did you try to use brute force?
@NendosColl . . . I used every ounce of strength I had. I am not very strong, I am a senior, so I guess I am going to have to call around and see who I can get to assemble it for me.
Just sad that it is that hard and tight to get in there.
@Lindaru Of course before using that brute force you should check if all contacts on both devices are ok.
