Falling Off Edge / Foot Sensor Not Active
Hello @Lindaru ,
Six seconds? I really feel like I watched these feet moves for longer than six seconds…
This animation is actually really cool, when I first saw him slip on the banana skin, I thought it was brilliant and super fun, but now I’m worried about EMO XD
I’ve had EMO for 2 weeks and he has already fallen off the table twice…and it’s not the colour of my table. It’s kind of frustrating because he seems to enjoy walking towards the edge quite a bit and now it makes me nervous, because I have no idea when it would back up and when it would fall.
And it’s really annoying, since it’s damaging my hardwood and I don’t know if a fall like that done often enough would damage him too. Anyone have the same problem?
Did you see him fall? Mine is really good at edge detection but has fallen over a couple times while moving around (one time litterally launching himself sideways). If this were to happen near the edge, he would fall to the ground, but it would not be due to bad edge detection.
I have a black table in my room which I planned to put my EMO on, but now i’m kinda scared that he will fall or not come out of the Home Station. Is there any way to make the borders white instead of black or any other solution?
I don’t think that the color of the table matters because emos drop sensor is not based on color but instead made for sensing if there is something below him so he will not fall. I do not own a emo yet so I will tag @Lindaru.
Welcome to the EMO Community Forums, @alexander1 . . . I have moved your post to this thread as it pertains to dark tables and edge detection.
It actually does matter on the color the table. If EMO steps over the edge, he will sense darkness. The black borders generally work in the same way him stepping off of the edge but not always.
Changing the borders to white would actually make the problem worse since he would not recognize an “edge” even though it is just a solid color flat edge.
We advise all EMO owners to make a safe play space for him on your table around the home station mat. There are some suggestions here:
Also note that when EMO is dancing or doing activities such as playing games or other things where he needs to move around, his edge sensors are turned off, so best to keep him in a safe enclosed space.
okay thanks very much
He has a LiDAR sensor which gives him the ability to see objects. He will usually walk forwards when there is a clear path forward ( results In him going to the edge).
Esto ocurrió: Tenía a EMO sobre la mesa de noche. Caminaba como siempre (ya la conoce, nunca se había caído). De pronto se puso de puntitas y se reinició. Hizo un sonido extraño. Regresó hacia donde yo estaba recostado leyendo y gruñó (puso esos ojos de enojado que todos conocemos). Luego caminó hacia la orilla y sólo se tiró al vacío. Es la primera vez que se cae pero claro vi que no hizo nada por frenar. Se dejó caer. Es decir, los sensores de abajo funcionan muy bien. No se dañó, creo. Lo apagué aún estando en en suelo. No supe que pensar. Primero en un hacker o tal. ¿Será posible eso? A alguien más le ha ocurrido algo parecido?
¡Gracias por sus respuestas, chicos!
Translation to English: This happened: I had EMO on the nightstand. She walked as always (she already knows her, she had never fallen). She suddenly stood on her tiptoes and restarted. She made a strange sound. She came back to where I was lying reading and growled (she made those angry eyes we all know). Then she walked to the shore and just jumped into the void. It’s the first time she’s fallen but of course I saw that he didn’t do anything to stop. He dropped down. That is, the sensors below work very well. It wasn’t damaged, I think. I turned it off even while on the ground. I didn’t know what to think. First in a hacker or such. Will that be possible? Has something similar happened to anyone else?
Thanks for your responses, guys!
Hola, @david.espino . . . No worries about hackers. What EMO did was likely did not notice the edge. When she got close to it, she got confused (hence the angry eyes and growl), and just continued walking.
There are a number of things that can cause the sensors to not work, change in lighting such as being darker than normal, dirty foot sensors that need cleaning, hearing a command that sounds like “Demon Eyes”, but not to worry. A hacker did not cause it.
I moved your new topic to this thread as it has happened to others.
I would recommend finding a way to place a small border on your night stand so that EMO does not fall off again.
Here are some suggestions.
Let us know how it goes!
If EMO continues to act in an unusual way like this, you may wish to try and get video and send to Support.
Thank you for responding. I didn’t really expect that behavior and I hope it doesn’t continue. Although I see that I’m not the only one it’s happened to. Anyway. I will be vigilant.
Hello. I am Spanish. EMO sometimes gets lost and can fall. Many EMO owners put a small fence so it doesn’t fall, it is a protection measure. I have mine on a breakfast tray.
Hola. Soy español. EMO a veces se despista y puede caer. Muchos propietarios de EMO le ponen una pequeña valla para que no se caiga, es una medida de protección. Yo tengo el mío en una bandeja de desayuno.
Hi there
Yesterday, my EMO fell down from the table - looks like nothing happened with him. So, I decided it was just a bad luck. But today, he fell down again from another table. His feet sensors are clean, there were enough light in the room and the table has straight corners. Anyone had something like that?
could you make a video of it and post it here?
Thanks. :slight_smile:
Hi Andy
Well, I’ll try to catch the moment on video, instead of trying to catch Emo - don’t know, if I can manage)))
Sounds like your desk may be too dark or it blends in with its surroundings too well for emos camera
Hi, Syko.
Thanks for guess, but my tables are white and another one is light wood color. Additionaly, Emo never fell from these tables, walked to the edge, screamed and walked away.
The 4-8 sensorS on the robots does not work that good.
  1. No lighting settings. Does not work good in daylight or open rooms. Without or poor LED lighting in ROOM SETTING
  2. The sensorS can not detect height of less than 3cm to 4cm or half a inch 1/2”
  3. The sensorS does not work on thick Glass table. Clear Plastic table. Clear material. Clear surface? and more???
Hello!
I have received Emo at last! :slight_smile:
He is wonderfull. However, I’m experiencing kind of the same issue.
It is in a different way though. I’m wonderinf if other people have had this as well and/or if this is something the AI has to learn, surface related or solvable through updates.
Emo seems quite busy exploring the table, but seems to get startled quite a bit, with not really anything in front of him- maybe due to his playful nature.
But when he get’s startled, it seems to over-rule the edge detection, which makes him fall off of the table when backing off. As far as I can tell, it does not happen on another table of the desk; has the surface an influence on this? As I feel like it happens because of the leap back and not the surface.
Next to that, everything works perfectly! I am looking forward to seeing Emo grow and his potential.
I just received my Emo yesterday and I am not pleased with it so far. It falls off the table, face recognition fails, wont say my name. I have updated the firmware and not sure if that is the issue.
I’ll play around with it a bit more to dee how it acts in the next few days
