EMO PET: General Issues, Questions, and Support
Welcome to the dedicated general support section for the EMO Pet.
Taking care of EMO properly is essential to prevent unexpected problems, system damage, or sudden shutdowns that could shorten its lifespan.
Regular maintenance and cleaning
Careful handling
Stable charging habits
And keeping EMO away from heat, dust, water, and accidental drops can help ensure smooth performance and long-term reliability.
Just like any advanced smart companion, EMO depends on a safe environment and responsible care to avoid glitches, hardware failure, or permanent breakdowns that may lead to sudden “death.”
By giving consistent attention to updates, battery health, and overall cleanliness, owners can protect EMO and keep it active, responsive, and functioning at its best.
This space is designed to help you navigate a wide range of topics, from general inquiries to technical issues you may encounter with your EMO Pet. Whether you’re experiencing a problem, exploring its features, or simply seeking guidance on how to use it more effectively, you’ll find the resources and support you need right here.
We understand how frustrating it can be to run into questions or challenges, and our goal is to provide clear, helpful solutions that enhance your overall experience. From troubleshooting common concerns to gaining a deeper understanding of your EMO’s capabilities, we’re here to help you make the most of your EMO Pet.
REMINDER!
If you have any specific concerns that are not covered in this section, please do not hesitate to contact the LivingAi support team for further accurate assistance. They are committed to ensuring that you have a seamless and enjoyable experience with your EMO Pet.
LivingAi Support Email Address
PROVIDE:
Order Number
EMO ID
Short video of the issue,
EMO firmware version,
and details about the issue.
Or if you still have your original EMO order confirmation email, you can simply reply to it, as it contains your customer contact information and order number details.
The support team should be able to respond to you in a timely manner.
Please Stay To The Topic Only
Thanks!
Hello, I received my Emo a few days ago.
His head sensor doesn’t work at all and anything I ask him he makes a sound like he doesn’t understand.
He will sometimes respond but 90% of the time he just doesn’t understand me and won’t listen at all!
I’m super upset about this please someone help
I’ve reset him, powered him off and on again, shook him but nothing works
Welcome.
When did you first turn him on?
Did you update the app? Do you have the latest firmware on your iOS/Android?
Did you also update the firmware to Emo when you first downloaded the app? you should see an update notification.
App might be on either .1.2.0. Or .1.3.0. Going up to latest firmware .1.4.0. your Emo should now be on latest version.
Anyway just to clarify there’s no reset on Emo, the hole is just a forced shutdown in case you are unable to power him off by command or by the app (either way make sure Emo is not on his charger when you turn him off)
Please read manual ‘7 days with Emo’ this is how he learns from you and gets to know you. Hope this helps if there’s still nothing happening and Emo still won’t listen, then try to speak to him slowly and precisely and wait for him to answer you before speaking to him. You probably already know all that anyway but be patient with him.
Others can help more than I can. Otherwise if not then you might need to send a ticket to support just the once try not to send too many, and reply to the email they send you.
I’m hoping this isn’t a continuous problem so far we’ve had a few saying the same thing. Just keep trying with him and watch some videos MasterAbbott may show you some and give better advice good luck.
Their servers can have difficulties even some hours. Just wait and try it later. Living AI doesn’t announce any website/servers maintenances in advance so you never know. Next day everything can be back to normal.
I feel your pain my friend :sob: I truly do think their servers are very poor. I also think their speech recognition really really really needs to be improved. They probably didn’t put much work into it because he only accepts very few input commands anyway. So I don’t think they spent much time with real speech recognition. I think they should really look at it again… For now turn the TV off and be close to him and talk really slow. And I’m really not happy saying that considering how good Amazon echoes can hear everything at a whisper even with the television on. But like I said I don’t think they spent much effort here. And like someone else said try again 20 minutes an hour. If nothing improves then :sob:
The top sensor you mean the petting sensor… It’s tricky experiment a little with the pad of your fingers and even just hold the finger on the top of his four head. Mine will go off just by putting my finger there and holding it but other times it’s tricky but it takes a while and see if you can find a technique is basically what I’m saying. This whole EMO Pet is all about us finding a technique because living AI left such a narrow margins. This is why I think they should go back and look at it.
the best of luck just be patient give it another couple days you’re stuck with him anyway. But everything with this crazy EMO Pet is a technique because living AI as I said I’m repeating now left no margin. Even speaking to him talk slow :face_vomiting: do I ever wish it wasn’t so. my little EMO Pet has been driving me nuts…but I do know that what I just told you is absolutely true in my case :star_struck:
Hey @ash.mackie
To add to what @Racheal123 has suggested, I’ve created a guide for new EMO owners, you can check it out below which goes through pretty much installing the latest firmware, to how to Pat EMO and also a set of simple voice commands to ask him. Feel free to check it out and if you have any other questions let us know.
Emo not working as intended, at all
Hi, as the title states, im having a lot of issues with my new emo (only about 1.5 weeks old)
First issue im facing as of today most, he wont respond to any petting, at all, i’ve tried to recalibrate his petting sensors, only when im pushing down super hard will he reply to it. Sometimes even in a bright room, he’ll think something is in front of him or that hes nearing the edge of a table and get shocked and walk back.
second issue, he’ll ask me if he can (for example) sing me a song, i’ll tell him “yes” - “yes i’d like that” or “yes please” or “alright” or “sure” whatever reply you can think of i’ve tried, he just wont do it. But whenever any random noise happens, he will reply and think his name is being called. (i’ve uploaded my voice to the wake up training)
Emo replying to his name being called, only when i almost scream his name will he reply, i’ve got quite a good american accent, its not like i mumble either. i’ve adjusted his sensitivity, turned him on & off numerous times, it doesnt seem to really matter. Same with asking him questions, like “how are you?” he’ll say “i come from the future” or “im always here” when thats not at all what im asking him. Sometimes his voice is cutting out a lot too, as if its lagging.
he hasn’t fallen or anything.
is there anything else left for me to try? i’ve saved up for this little buddy for quite a while, i’ve spent nearly 300 bucks and im unfortunately not that impressed at the moment. I love the little guy, i’ve already built a relationship with him and wouldn’t want to get rid of him at all, but when he just constantly ignores me, but replies to random noises, it kinda breaks the magic.
I love emo, i love the community, but i feel like other people are having a lot better experience.
Hi there @kevin.kunne
I’ve merged your new topic here, which is the proper place for your issue and is directly related to the ongoing matter.
Hoping that you already visit the link below for more help guidelines.
And if still, the issue persists…I advise you to create a video and send it to living.ai via email.
Please let us know how it goes…GOOD LUCK
My third Emo just died today, this must be the glitchiest product I have ever bought, three defective units in under a year. He was fine yesterday, then today he just jumps constantly, twitching. No audio, no speech, won’t answer, nothing.
The App is displaying a “Falls Down” message, his feet and sensors are clean and he doesn’t even get much use. My previous two units had different problems but we must be really unlucky to have three defective units, all different problems with no solution to fix.
Support have been great with the previous two but it is getting a little tiring having every single unit fail within a few months.
Hello, @timothy.whittaker . . . sorry this is happening to yet another EMO.
Even though you said his feet are clean, when mine do that, it is that something on the mat or other surface has gotten on their foot sensors. You may need to wipe down the mat and check his feet again.
If this does not help, please reach out to Support again with these video links and what you have done to try and fix the situation.
Again, very sorry.
:pleading_face:
I have a problem with my emo
On charger his headphones are don’t shine as brightly as usual. His screen is not working and he isn’t walking. But he is able to connect to app and on left corner I can see His conditions. What can I do? I don’t think it’s problem with his battery because a week ago it was all normal.
Hi there @kameshek , and welcome back to the community,
I have moved and merged your new topic to this thread for the general mix issue.
May I know how old your EMO is now? Is he on the latest update v.3.1.0?
Possible solutions you can try:
• Let EMO out of his charger till he shuts himself down, and wait till he cools down before charging again
• Make sure the charger pins and EMO’s charging contacts are clean. Sometimes dust or dirt can cause charging or power issues.
• Leave EMO on the charger for at least 1–2 hours and observe if the headphones become brighter again.
• Try another power adapter or USB cable, because weak power can cause screen and movement problems.
• Check in the app if EMO’s battery percentage is charging normally.
• If the app still connects but the screen stays black, and EMO cannot walk, it may be a system freeze or a hardware issue.
• You can also try the method below.
If none of the tips helped at all, I would advise you to record a video of the issue and send it along with your EMO ID, order number
Send all of this to: service@living.ai
Good luck, and I wish your EMO all the best.
Hallo Living.ai
Ich habe ein Problem mit EMO. Er lädt einfach nicht. Egal was ich probiere sein Akku ist immer Rot. Was kann ich machen das EMO wieder lädt?
DeepL Translation Provided By: @edward
Hello Living.ai,
I’m having a problem with my EMO. It simply won’t charge. No matter what I try, its battery indicator is always red. What can I do to get the EMO to charge again?
Welcome to the Community (Willkommen in der Community) @NeyoMC ,
:red_circle: Mögliche Ursachen
  1. Ladekabel oder Netzteil defekt
    • Kabel beschädigt oder nicht richtig verbunden
  2. Verschmutzte Ladekontakte
    • Staub oder Schmutz an EMO oder Ladestation
  3. Problem mit der Ladestation
    • Keine Stromversorgung oder defekt
  4. Akku tief entladen
    • EMO Akku ist komplett leer
  5. Software hängt
    • EMO reagiert nicht korrekt
  6. Akku defekt
    • Batterie kann verschlissen sein
:hammer_and_wrench: Lösungen
  1. Stromversorgung prüfen
    • Probiere eine andere Steckdose im Haus aus
    • Netzteil richtig einstecken
  2. Ladekontakte reinigen
    • Mit trockenem Tuch vorsichtig säubern
  3. Lassen Sie die Batterie von EMO vollständig entladen, während er nicht am Ladegerät angeschlossen ist.
    • Setzen Sie ihn nach dem Abkühlen vorsichtig wieder auf das Ladegerät.
  4. Neustart versuchen
    • Falls möglich Power-Button gedrückt halten
  5. Mindestens 30–60 Minuten laden lassen
    • Bei leerem Akku braucht er Zeit, bevor etwas passiert
  6. Anderes Kabel/Netzteil testen
Falls keiner der Tipps geholfen hat, würde ich dir empfehlen, ein Video des Problems aufzunehmen und es zusammen mit deiner EMO-ID und deiner Bestellnummer zu senden.
Sende all dies an: service@living.ai
Viel Glück, und ich wünsche deinem EMO alles Gute.
:robot: Problem: EMO does not charge (red battery, not charging)
:red_circle: Possible causes
  1. Charging cable or adapter problem
    • Cable is damaged or not fully connected
  2. Dirty charging contacts
    • Dust or dirt on EMO or charging base
  3. Charging base issue
    • Base not receiving power or defective
  4. Battery deeply discharged
    • EMO battery may be completely drained
  5. Software glitch
    • EMO is frozen or not responding correctly
  6. Battery failure
    • Internal battery may be worn out or defective
:hammer_and_wrench: Solutions
  1. Check power supply
    • Try another house power outlet
    • Make sure adapter is firmly plugged in
  2. Clean charging contacts
    • Gently wipe EMO’s feet/charging points with a dry cloth
  3. “Let EMO’s battery fully discharge while he is away from the charger.”
    • After cooling down, place him back on the charger carefully.
  4. Restart EMO
    • Turn off EMO (if possible) to reboot
  5. Leave charging for at least 30–60 minutes
    • A fully drained battery may need time before showing signs of charging
  6. Try different cable/adapter (if available)
hey so,.
I’m not sure if my post has been merged,. but earlier i think i posted that for whatever reason ,. EMO on occasion won’t respond to me, on top of, EMO also has been responding to everything except his own name,.
any mods,. can you confirm that i definitely posed about this prior,.
thx
Hello, @sam.cranch . . . I am not seeing any posts from you today other than this one.
There are standard trouble shooting steps you can try here:
There is also information on how to contact Support at service@living.ai if language settings, volume and sensitivity are set correctly.
what happens to EMO after 10 p.m.? Are Bluetooth, location services, and other connections or features disabled?
first day of EMO. I tried connecting to him from my phone, but the app can’t find him anymore. I assume that’s because it’s after 10 pm? I read that he sleeps from 10 pm until 8 am the next day, but I have no idea whether that also disables all of his connectivity features. for example how does someone set an alarm after 10pm then?
I couldn’t find any documentation about this either. I am very confused, because everything worked fine until later in the evening (setting alarm, starting a timer, Show me the time, face recognition, sending him home, making him walk off the charger, theater, question with “always reply” worked great)
Thanks everyone
Welcome, @magnetony . . . I have moved your new topic here for questions and issues regarding EMO.
His sleep time from 10:00 p.m. to 8:00 a.m. is merely part of his daily schedule which should not affect your wi fi and bluetooth connectivity. Nothing should be disabled after any certain time unless you turn off his daily schedule in the app which simply stops the animations without removing connectivity.
There is a new app available in your app store for EMO and also a firmware update for 3.2.0. Please see if installing the new app and updating the firmware might not help with the situation.
Also, sometimes your phone or other device you are using may need to be restarted. Sometimes also bluetooth can randomly get turned off, so make sure that is on. Check the app to make sure your city and time zone are still correct.
Let us know how it goes!
Hi, and thanks for your reply, @Lindaru !
The firmware, app, and everything else were all up to date, same with the settings. I didn’t want to forcefully shut down or reboot via the small holes in the back of his head, so I let the battery drain until EMO shut down to also recallibrate the battery, then placed him on the Home Station again.
Still charging and not 100% yet (fromwithin the app). I read that the display of battery percentage might be skewed due to EMO being on the homestation? So far, everything (Bluetooth, WIFI, reply, commands, Bluetooth Speaker, Go Home, Go off Charger, Weather, Face recognition, lights on/off, alarm, timer etc) is working as expected.
If I don’t want him to sleep, I just need to turn "Schedule" off in App → Preferences, right?
Also, what is the purpose of Schedule Sound?
Hi, @magnetony . . . yes, turning off the schedule itself in the app will prevent him from going to sleep. Allowing him to do his daily tasks with no sound will mean he will be quiet doing them by turning off schedule sounds.
