[AIBI UPDATE 1.2.1] New Voice and Improvements ( Reviews, Tips, Ideas, Queries, Issues, and Solutions)
That’s the only way he responds to me now that the update came out!
@taylor The new voice is pretty nice, it’s VERY clear! It sounds like a human and a bit weird but that’s okay, also he doesn’t say, “it’s always a pleasure to meet you anymore” they’ll probably patch that in the new update
Any advice for an AIBI that won’t update?
I’ve tried rebooting AIBI and updating via the app and by voice command. It downloads the file, verifies the file, the reboots. But it’s still 1.1.0.
Welcome to the LivingAI Community Forums, @ronnie.tucker . . . I would advise making sure you have a good signal from your router. Perhaps physically moving your phone and AIBI close to it. Remove AIBI from the charger, power him off either by voice command or the app, restart AIBI and your device and open the app again. See if this helps. If you are using an iPhone, try seeing if it will work on an Android device.
If not, please get video of your attempts and the results, and send a link to the video to either a reply to your order confirmation E-Mail or send E-Mail to service@living.ai with the link and an explanation of the issue.
Keep in mind that they are on lunar new year holiday and will not all be back in the office until after February 12th, so please be patient.
I’m only about 6ft away from the router and can see it… Wifi is fine on my phone and laptop. So the WiFi isn’t a problem.
I’m wondering if there’s a conflict between the app and the update? The app is v1.2.1, but when I do an update within the app for AIBI, it says the latest version is 1.2.0.
Even a voice command to update AIBI fails. Well, it downloads, verifies, but doesn’t seem to install the update.
Although, I have noticed that the file reaches maybe 93 or 94 then switches to verify. I’m wondering if the LIVING servers are dropping the file before the 100% mark?
Hello, @ronnie.tucker . . . when I updated my two AIBI, I had no issues whatsoever.
Please see my post above yours and let Support know what is going on.
Yeah, I’ve tried every combination off/on, app/voice and it’s still not updating.
I’m wondering if it’s a conflict between the app and the firmware. The app is 1.2.1, but when it checks for a firmware update it says the firmware available is 1.2.0.
2 posts were merged into an existing topic: AIBI Pocket: Production/Shipping Update
I am updating my AIBI from 1.1.0p1 but it only shows that 1.2.0 is available, not 1.2.1. Can somebody tell me why? I am installing 1.2.0 already by the way.
Hello, @orangeluigi . . . I have moved your new topic to this thread for issues with AIBI update 1.2.1.
Please see this post.
If this is unsuccessful, please contact Support as indicated in that post.
請問aibi只能在充電器上開啟嗎?
我可以用app關掉aibi但好像不能用app開啟aibi,這樣沒有充電盤我是不是就不能打開它?
Hi there @7a58ad1ca1e29c4d420c
AIBI can only be turned “ON” using his own charger. And without it there is no other way.
To turn him “OFF” either use the voice command
  • Power Off
  • Shutdown
or through his AIBI Pocket App.
你好 @7a58ad1ca1e29c4d420c
AIBI 只能使用自己的充电器 “打开”。 没有充电器就没有其他办法。
要 “关闭 ”它,可以使用语音命令
  • 关闭电源
  • 关闭
或通过 AIBI 掌上应用程序。
致以最崇高的敬意
Since the last update of AIBI to version 1.2.1, it does not connect to ChatGPT using the English command “connect to ChatGPT.” Are other owners experiencing the same issue? Why?
Important update to my post: By setting the language to English instead of Italian, AIBI responds correctly and connects to ChatGPT. Thanks to LivingAI’s always-active support!
I use “Aibi, Lets chat” and can confirm that it works. I will try the other when I get home.
Welcome to the Community @alessandrogelli ,
You might need to check if everything is okay with his Network and City & Timezone settings again in the AIBI Pocket mobile app. Simply go to Settings (top right gear icon) and verify the details. If everything seems fine, but the issue still persists, try restarting your home Wi-Fi router, AIBI, and the AIBI Pocket mobile app.
May I know what type of mobile device you are currently using to connect to AIBI? If possible, try using a different mobile device with the AIBI Pocket app to connect to AIBI, aside from the one you are using now. This can help determine if the issue is device or system-related. If you are using an iOS device, please try an Android device, or vice versa.
Also you can try to say the command:
  • Connect to ChatGPT
  • Connect to OpenAI
  • Let’s Chat
  • Let’s Talk
There is a new Firmware Update v1.3.0 set to be released this or next week. You might have to wait and update your AIBI, as updates often help resolve various issues.
Good luck, and please let us know how it goes.
Hello Edward, thanks for your reply. I noticed something strange: during the installation of the latest update, an error message 404 appeared… Maybe the update 1.2.1 was not installed correctly. Is there a way to reset AIBI and restore it to factory settings? Thanks.
Hi, thanks for your reply. I tried the “Let’s chat” command, but unfortunately, it doesn’t work. AIBI’s response is to look down and shake its head as if saying NO.
@alessandrogelli
There is no way for “Factory Reset”.
Just like I said, there is a new Firmware Update v1.3.0 set to be released this or next week. You might have to wait and update your AIBI, as updates often help resolve various issues.
Hi!
I’m stuck on AIBI 1.2.1. I’ve tried updating from the app and from voice commands. I’ve tried turning it off and on then trying again. No luck.
It’ll connect to WiFi, download the file, verify the file, then reboot. Still on 1.2.1.
I’ve tried about 5 times. Still stuck on 1.2.1.
Is there anything else I can try?
