United Kingdom members and owners
Dose anyone have a Emo in the United Kingdom and how Dose it perform?
I do. He performs very well!
And how do you charge it a plug converter or can you connect the skateboard to the computer.
Unfortunately you’ll need an adapter from an American 2 pin plug to the uk three pin plug. They’re not expensive, just a bit irritating.
I was actually wondering about that and I think it would be better if they changed the adapter depending on the country’s type, i think it will just make things easier for the user/customer.
Do not try plug adaptor in Holiday Inn Express. I am amazed when I went to Wales, the motel staff was understanding of me accidentally blowing out nearly every outlet I used. ( Yes, it was the correct type of adaptor ).
US to UK Plug Adapter | MyTravelPal® USA to UK Travel Adaptor With 10A Fuse | For America / Canada / Japan Appliances | Type A / Type B https://www.amazon.co.uk/dp/B096PPKVJP/ref=cm_sw_r_other_apa_glt_i_ARRVZ1D97DFBD7AASWPF?_encoding=UTF8&psc=1
Hello, may I ask which delivery company delivered your Emo? do you have to pay for Import Tax? Hope you won’t mind to share the details as I`m thinking to order one. Thanks :slight_smile:
Yeah. For me I had yodel deliver my package, and I don’t think I had to pay import tax, but if I did, it was included within the price of emo. Also, some people have said that Royal Mail delivered theirs, so it’s either yodel or Royal Mail. Hope that helps!
Thanks for the quick reply. :slight_smile: can’t wait to get one.
No problem! He is great and I’m glad you can’t wait to get one!
Is the link above a reccomendation for adaptors? I’ve been looking for one on amazon but not sure on voltages or wattages, would love if anyone has any reccomendations for a extention lead!
Hi @shaunamccormick
I shared a link on the other thread regarding recommended adaptor/USB-C cables. I’ll share it here as well, just see further below the links to the Amazon store.
If you’re living in the UK. You just need to find a power board that is similar to the one I’ve linked below as the voltage will be compatible if you get something similar made for UK homes.
For USB-C cables, they are pretty much universal, so you don’t need to worry too much about those. I sometimes use my Nintendo Switch USB-C to charge my EMOs Skateboard :slight_smile:
Power Board
https://www.amazon.com.au/Protection-Protector-Universal-Computer-Charging/dp/B09T6T99G9/ref=sr_1_16?crid=21XHV18P5YX&keywords=usb+power+board+with+us+converter&qid=1657779917&sprefix=usb+powerboard+with+us+convert%2Caps%2C213&sr=8-16
USB-C Cable
https://www.amazon.com.au/sweguard-Charging-Transfer-Samsung-More-Green/dp/B09MRJRZBX/ref=sr_1_16?crid=3JBXHSH1YFT4L&keywords=2+meter+usb&qid=1657780060&sprefix=2+meter+usb%2Caps%2C201&sr=8-16
