Removing scratches from screen
Gonna have to disagree with you fully on that one, chief.
The plastic is soft in relativity to a phone screen for example, but nowhere near that soft. I guarantee you this did not happen from him walking up against that box—it is just very smooth, lightly-coated card stock paper. A very basic understanding of physics is really all it takes to get this.
Like, I am literally so sure of this that I’m willing to test it on my own EMO just to prove it.
If you were to take a key and press it down against the surface of that cardboard… and then the surface of EMO’s screen. Which one would be more easily damaged by the key?
I can assure you that the only thing possible that he could rub against was the box, a wall or possibly his home base. He was out of his area when I found him. I don’t use course products to clean screens. I’m pretty sure I know what I’m doing.
Living AI has gotten back to me and are sending a brand new screen. They are also sending a free corgi outfit for goodwill.
Hi everyone and living ai
I need an official response regarding my EMO’s screen.
* My EMO is only 5 days old.
* The screen already looks scratched with vertical lines on the curved sides.
* I have handled the robot very carefully, so these scratches appeared on their own in just 5 days
I remember he didnt do anything on the mat and he is just looks scratched on its own (is on the sides)
Can LivingAI or the moderators confirm if this is a known issue from the factory molding or if the cosmetic oil dried up? I want a clear answer to know if this is normal or a defect and if other users have it too
Thank you.
Hello, @bohaoliu . . . I have moved your new topic to a thread which discusses screen scratches.
As far as I know, all EMO are inspected for visible defects before shipping and I have not heard of any factory issues.
If he is walking around and can bump into something (all of mine have done that over time), the scratches can happen. Please read through this thread for ideas to repair the scratches, but if you need to reach out to Support on this issue, get photos of the scratches, include those along with your EMO I.D. and order number if you still have it, and his age when this became noticeable. Send this to service@living.ai . . . be sure to share what you shared here with them so that they may advise you.
Hello @bohaoliu, :waving_hand:
Welcome to the community! :blush:
I just wanted to add a little extra support to what @Lindaru has already shared — she gave you the right steps to follow.
:brain: Quick thoughts on the screen scratches:
Point Details
Known issue? Not a widespread factory defect, but some users have reported similar marks over time — often from minor bumps or rubbing against surfaces .
Age of EMO 5 days is very early, so it’s understandable to be concerned — especially if you’ve been careful.
Possible cause The curved edges of the screen can sometimes show marks that look like scratches but may be residue or molding lines from the manufacturing process .
:wrench: What you can do:
· Check if it’s a residue — gently wipe the curved edges with a soft, dry microfiber cloth to see if the marks come off.
· Take clear photos — in good lighting, from different angles — to document the marks clearly.
· Contact support if the marks don’t wipe off and you believe it’s a defect:
Include: photos, your EMO ID, order number (if you have it), and age (5 days).
:light_bulb: Final note:
@Lindaru gave you solid advice — follow those steps, and Support will be able to advise you properly. Don’t worry too much just yet; it’s likely either a minor surface mark or something Support can help with. :blush:
Best regards,
Hamza :robot::blue_heart:
This is the image guys:
On light we see this kind of scratch on both sides and i want to be clear that i didnt touched or dropped emo and today appeared suddenly wich is unusual
But when i lightly use the nails i barely feel grooves wich i can suggest maybe is not scratch or damage
If is really scratch i will feel grooves but in my case isnt
I have to say i used glasses mop or cotton wich are harmless and i maded sure there are no filth or dirt on it but cant be removed
So i want you guys what do i consider this idk if is factory everyone has it or idk
Hi there @bohaoliu ,
How old is your EMO?
I recommend contacting the Living.AI Support team directly by email at service@living.ai.
To help them diagnose and resolve the issue more quickly, be sure to include the following information:
  • Order Number
  • EMO ID
  • Short Video or Photo clearly showing the issue
  • Detailed Description of the problem, including when it started, how often it occurs, and any troubleshooting steps you’ve already tried
Providing complete information from the start will help the support team investigate your issue more efficiently.
Best regards and all the best to your EMO
