I orderd 7 screen protector for apple watch 7 with 45 cm in a package for under 10 Euro. It should be fixed.
A screen protector with round corners!
Thank you for your advice to fix scratches. I have some too, because the wooden wall of my playground for EMO was to high and scratched on the screen of EMO.
Absolutely, it will like due to the chemical make up thats why you never do it directly on an LCD display
However the cover over emo’s screen is acyrlic glass effect thats same material most watch cyrstals are. I have used polywatch on various stuff not just watches.
You dont touch the actual screen on emo at anytime.
polywatch has a small amount of abrasive material its why watch restorers use it to restore cystals my favorite is wrist watch revival hes used it on 5k rolex’s and stuff .
It sands of a very fine layer off as well as filling in deeper scratches
