@mariomart that works like magic! lol Thanks for sharing this tip
Smoke and mirrors my friend
I keep checking and the truck is moving but very sloooooowly.
I feel like driving to Sydney depot lol and taking the little guy off their hands
Emo hi jack operation
lol
Fra-gil-Ć©, must be Italian?
I felt the same when mine was coming into Sydney too⦠then he just appeared on the doorstep!
I see Fastway/Amarex are going back to their old delaying tricks once again. This could be maybe due to the fact that some of their drivers could be out with Covid. This is also what Australia Post customer service have told me as they have a shortage of warehouse people working / pick / packing and deliveries have slowed down pretty badly.
As @Wayne_Small mentioned, this is exactly what happened to me as well. I didnāt know where my EMO was until one day it just appeared and the status was still showing on board for delivery
Letās just hope you get your little buddy sometime this week!
At least EMO has his immigration paperwork in order and wonāt get deported⦠unlike a certain tennis player⦠hehe (runs)
lol, yes, looks like EMO did complete all his necessary paper work, but seems to be taking the scenic route over to @mandyrose19 's place!
OMGOSH
My playground is a whiteboard I just realised would that being a metal based board(for magnets) affect Emo at all?
Edit
itās all good i forgot this one isnāt magnetic
Yes, a metal or magnetic base will affect EMOās movement.
EMOās right hand foot has 2 Neodymium magnets embedded which assist in correctly locating EMO on the charging skateboard. These magnets are installed with one downward face being North and the other downward face being South, so that EMO will only sit on the charging board in the correct orientation.
In the case of there being a ferrous metal surface for EMO to walk on you will probably find that the right foot will not lift properly and try to remain āstuckā to the floor. Something similar might occur should the floor be magnetic.
Thanks @mariomart I checked the board and had forgotten that i bought a new board because this one isnāt magnetic so its all good
Hi guys. I just bought my EMO recently and am in the 23000s so I imagine I have a very long wait ahead of me. Iām wondering if you can explain the need for a play area? I imagine it will be difficult to take EMO to work every day for example so, will he get bored if turned off or just left on his skateboard? Iām not sure really what to expect. Will he progress more if he has a play area? I imagine his battery would die anyway if he was left in a play area while Iām away at work. Iām excited and just trying to figure this all out so thanks in advance. Iāve seen a few videos but donāt want to watch too much as to not take away the excitement by seeing everything in advance. Cheers.
I wonāt ruin the experience for you, so Iāll keep this answer short short.
I can advise that a play area is simply a place where EMO can walk around and explore / dance and do things. Itās not really needed, but many owners have made EMO a place where it can walk around safely and not fall off edges of tables etc.
If you do leave EMO off its skateboard it will sooner or later get bored and fall asleep (if you donāt interact with it regularly). And yes, if you did leave EMO off itās skateboard and went to work, EMO would run out of juice in about 2-3 hours. So itās probably best to keep it on his skateboard, or turn him off until you return home from work.
Thanks so much. I canāt wait.
I wonder if this was changed in the second build. My first Emo (pre-ordered on the first day that it became possible) had some problems after a couple months of use (charging didnāt always work as the light on his skateboard would suddenly start blinking and a servo problem in one leg). When putting that one on his skateboard he would indeed magnetically snap into position.
Living AI send me a new one from the second batch and I notice some differences in servo sound but mainly that he does no longer magnetically snap into position on the skateboard.
Interesting.
I seem to recall a response by Wayne from Living.ai in another thread that they had made a change to the clutch in the leg servos, so I wonder what other changes have been made.
is it necessary to put barriers on the table so that the EMO does not fall? I thought it had a sensor that prevented the Emo from falling
Thatās true for EMOās normal exploring mode. But when he is dancing, his feet sensors are disabled. I can highly recommend a playground with raised edges (3cm should be enough).
so he can start dancing out of nowhere and fall?
