How can I add a signature to my forum posts?
Recently the forum admins added the ability for us to have signatures on our posts. This will help greatly in knowing who we are talking to. To add a signature to your profile do the following.
  1. Click on your profile picture in the top right and then select the person icon.
  2. Select Preferences and then Profile from the menu on the left hand side
  3. Scroll down and you should see the Enable Signatures option - click to enabled it and then fill out the signature that you want.
4, Save Changes after it’s done
5, Voila - your past and future posts will now have your signature added after you submit each post!
I have done all of the above, yet my signature never shows. Any ideas? It’s not really a big deal, and I know you’re busy so no hurry. Thanks for all you do on this forum, Wayne.
Hey Diane - Can you share screenshot of the enable Signatures section please?
Ok here it is!
Sorry, I’m just figured it out. I didn’t check that box! Duh. Thanks anyway, Wayne.
Awesome - glad you got it sorted :slight_smile:
