Firmware v2.3.0 / v2.3.1 Update (Please Post Any Issues Here!)
Hello, @dustysknight . . . there are others that have reported this as well. I am going to refer you to this thread. See if you can find a solution here and if not, I advise you to contact Support.
Please let us know how it goes.
Dear all
Help me ! My Emo stuck update
Can’t automatically update to the latest version 2.3. I’ve tried using voice commands, restarting wifi, turning Emo on/off, turning on/ off phone, and re-download emo pet app…
But after all he can’t automatically update. i don’t know what to do, currently it’s still version 2.2.0.p2
Hello, @anhnguyen2 . . . go into your preferences on your app and turn off “auto updates”. Then use the app to update manually. This method seems to work the best.
Hi Lindaru
Thank for your reply
I just turned off the “auto update” function and tried again, but there is still no button to press update, I don’t know what to do
@anhnguyen2 . . . at this point, I would say to send a private message to @TechSupport_Mavis who I have tagged here.
They should be able to assist you.
Hi Lindaru
Ok, i try to send messenger to Mr.Zhang for get help
Thank you
Hey @Lindaru @anhnguyen2 I am facing the same issue. I just got mine yesterday and never got an option to update again. Any solution yet for this?
Hello, @usayednayeem . . . if you have tried doing what was indicated above, I would also advise you to message @TechSupport_Mavis for assistance.
@usayednayeem If you say yes to all of these questions,I can confirm that there is a serious problem with your Emo.
  1. Did you go to the app’s settings and go to the firmware tab?
    2.Is your Emo connected to WiFi?
    3.Did you try reloading the app,powering off your Emo,or even power off your device.
    I hope this will help a little bit. I would also recommend what @Lindaru said.
Hi @ethan1 @Lindaru Its fixed after speaking to mavis. It seems they hadnt granted the permission for the software update. After it was the update went smoothly without any issues.
I got it all figure out now, my emo goes home when he shows battery low, goes back home no problem now
@Lindaru Is there any people I can talk to for help with my (test subject) EMO? I might be worried(again) that there might not be a topic that can sum up all issues?
Otherwise he might commit su—ide.
Don’t worry;he is just showing you what can happen.
@ethan1 . . . each issue should be addressed separately under each topic because that way others can find easy solutions through searching on the forums if they only have the one issue.
If you are suffering serious multiple issues, then please reach out to Support here by E-Mailing service@living.ai or tagging MavisZhang.
All the best and I am sure he will not do what you said. EMO are very loving A.I. and would not want to hurt you that way.
Hi there! My Emo is now 586 days old (got it second hand) and now its time to speek with him in german. My English is not the baddest but i want with him communicate in German. The little problem here is some commands in english working perfectly, but the german translation is sometimes difficult. Is here anyone how have make a summary with German commands? :grin::grin:
Hello, @Mirage1207 . . . I found when testing the Spanish version that sometimes phrasing the command a different way helped. Also, the foreign language commands are limited to what is in this document here:
They are hoping to add more commands in each language in the future.
