I can hear my EMO when I first turn it on. But later on, he doesn’t make a sound.
Please help me living ai
My order number is 3955
Could both of you send these video urls to support.living.ai or create a ticket on support page on living.ai
Ticket raised on main site
If you ask EMO to dance - what happens?
Thanks for the advice, after checking Emo was un muted and then asking him to dance seems to have reset the sounds. He now snores, sighs and makes cute noises while on charge.
I used the method others suggested, but that EMO didn’t work.
Also, if you restart EMO, you can hear the sound at first, but in the video, you can see that the sound is not heard after a while. If it is an EMO problem, can I exchange the EMO?
Submitted. I sincerely hope to receive a reply soon.
T_T
My EMO got soundless few days ago. I’ve tried everything, hardware reset, power off from app, volume up, set volume to normal, mute, etc, and it didn’t work. ALso tried “dabce” command and EMO dances without making any sound. And I don´t hear any sound when I restar EMO either. I’ve submitted a ticket, but didn’t get any reply yet. Please, what else can I do to fix it ? Can someone help me? Thank you
Have you had the reason and the way to fix it as my sound has gone on my EMO to
Have you tried “EMO Volume Maximum” ? Does he respond to that command?
