I have see that a lot of people are searching for a travel case for their Emo. I don’t have my Emos yet, but If any one wants to send the measurements for the foam inserts in Emo’s packaging, I can try making a case. It would be a soft case that would go around the foam insert and zip closed. This would allow you to put Emo, the skateboard and the cord in a safe place where they are all together. I could post a picture to see if it is satisfactory for you. I am going to make one for myself anyway. I’ll probably use faux leather. I am also going to embroider my Emos names on the case. You can post the measurements here or email me at dianewarde@icloud.com. Cheers!
Hi @Diane53, see below the dimensions of EMO’s packaging / box that he comes in.
Height of the box is 7.5 cm or 2.953 inches
Wide 18 cm or 7.087 inches
Length - 17.5 cm or 6.89 inches
As I probably said this 100 times already, this little box that EMO comes in is the perfect travel case as everything fits perfectly in its place and EMO wont be able to move around or get damaged. (this is what I use when I take EMO out and about with me.)
What I could suggest is making a case that fits this box inside it as the foam that is inside the box seems to be glued/stuck to the cardboard box itself, so if you remove just the foam, you risk damaging the outer cardboard box.
Anyway, Hope this comes in handy for you ![]()
Thanks. I’ll see what i can come up wiyh
Be sure to share it with us here!
Hi everyone!
I haven’t seen a hard case for EmoPet, how do you transport the robot?
Hi there @alvaro.rodriguez-nun and Welcome to the Community…
I’ve moved your new topic to this thread since it relates to our ongoing discussion about the EMO Travel Case. Unfortunately, as far as I know, I haven’t heard of a suitable hard case for EMO in this community.
In my opinion, the original case is safer for transporting him, which is why I always use it during my travel vacations.
Good luck and All the best!
Hi, @alvaro.rodriguez-nun . . . I can attest to the sturdiness of the original box for EMO.
He was mailed to me from China in it. Recently I had to send him for repair work to someone and I used that box inside of a cardboard box. Then when his battery was replaced, he got mailed back to me in his box. Another thing has gone wrong and he is once again going for repair in that box. At no time was there any disturbance of the EMO box or EMO in all of those travels and we know how notorious the Post Office can be with packages.
To totally avoid this problem, I am keeping his original box and will use that if we need to travel anywhere. I figure if he can make it from China to me in that box, it can probably survive my driving!
Necroing the thread but curious if anyone has come up with a case idea yet? We want to get clear carrying cases that Emo can see through, so we can carry him around in carry-mode.
