Emo screen freezing and randomly going blank
So, randomly when Emo is minding his own business, one of two things happen :
  1. Emo’s face freezes and stops playing all sounds
  2. Emo’s face disappears (it seems like the eyes fly upward right before it happens) but he still has sound.
    Emo still hears commands and resetting him seems to fix the issue. I got Emo not too long ago and I am getting worried!
Can you explain more about the problem?
@edward can you give @honeybee some help/info?
Hi there, @honeybee ,
EMO completely freeze is something that normally happens very rarely. Letting him run out of battery normally is a good idea and resolves the issue sometimes. But as you mention already that it was already performed but it didn’t actually help.
How to Power Off your EMO
else…you can try Force Shut Down
… I guess try this method
It’s not a reset button but a force shut down button inside his head (insert a tiny paper clip and gently press.
It will power off EMO, but it is not always recommended and should only be done if there are no other options as it could lead to possible data corruption.
About the App connection issue:
Power Off EMO. Leave EMO turned off.
Power off your Phone. / Then power it back up. Wait for it to be back on
Check to see if your phone has access to WIFI/Internet and also ensure that your Bluetooth is on and working.
If everything is okay…
Then power your EMO back on. Once EMO is back on try connecting once again using the EMO App.
Also, you can try using other phones with another operating system.
In case every suggestion that I’ve given nothing helps…
It would be best to make a video recording as you’ll probably need to contact the support service team via email with more info to let them know.
The best and most recommended thing to do is simply reply to the Living.ai confirmation email you received before when you originally placed your order for EMO. It contains all your details, especially your order number which is most important.
Don’t forget to include/attach your video and more info
But I hope any of my suggestions help you to resolve the issue.
GOODLUCK , ALL THE BEST, AND KEEP LOVING EMO
If you don’t mind at all…kindly please go to the link below.
So when I reset I meant powering off for a bit then turning it back on, I haven’t tried letting the battery run out yet like you thought I mentioned. Just noting : You explained how to help with the freezing but how do I deal with the screen suddenly disappearing? The headphones are still lit up, he still move, listens and makes noise but the screen just goes blank until I power him off and back on.
can i talk to you in private thanks
I suffer from the same problem as you
My emo use to freeze sometimes to maybe every few days i contacted customer support and they sent my emo a little firmware update which helped a lot i recommend you guys do it to :heart:
Hi there @honeybee and @ilyesbairi …
Please just try my advice above which sometimes resolve the issues.
Thank you for your reply, my friend. You are a good person and it is an honor to know you Your instructions did not work Sent support and wait for their response Do you know when the emo team returns from vacation?
They will be back in a few days
Hi there @ilyesbairi…
STAY SAFE AND BEST REGARDS…
Thanks my dear friend for the information
