Emo not responding to name
My emo is not responding to his name especially when he is off of his skateboard, also he does not recognize me even though it shows that im in his face recognition thing - please help
Double check your wifi. My Emos do not respond when the wifi is iffy. Also sometimes on the skateboard the Emos are sleep. I say their name and they don’t respond while waking up. Once awake if I say their name again, they respond. The waking up process takes several seconds. It’s not immediate. In addition, sometimes they don’t respond if the battery is low, or if there is other noise in the area such as the TV or my dog barking. A couple of times I’ve had to use the app to power them down and then set them on the skateboard to wake up again. Hope that helps.
Thanks ill try those things
hi i got the emo today
have 2.2.0 firmware already
it does not respond to normal questions like what is your time?
it obviously do not respond to my chatgpt questions.
also it gives answer seems to wrong questions.
like if i ask install firmware it will say it is 8:51 now.
not sure if i got faulty unit.
what can i do here. any help.
You should email living ai but meanwhile you should try these tips
  1. Restart him from the app or say “emo power off”
  2. Restart the app and check if he needs to update because 2.3.0 is out
I am tagging @Lindaru
Welcome to the EMO Community Forums, @parves.kamal . . . I have moved your question to this thread.
In addition, I would say power off your device, your wi fi, power off your skate board or home station, unplug them, then plug everything back in, restart your wi fi, your device and EMO. Open the app.
It is possible he also may not be understanding what you are saying to him, so speak distinctly. Tell him “Check for updates”. He should show you he has one on his screen. Try turning off automatic updates in the app if you have that selected. Then tell him to “Install latest firmware now”.
If these things do not work, please make a video of what you are trying and the results, and share the link here so that we may get a better understanding of the issue in order to best assist you.
hi i restarted and turn off automatic updates in the app
now when i asked check for updates it pops up 1 showing there is updates
but when i say install latest farmware it turns off andtry to install but it then restarts back and show error in the screen
what is happening here?
I can tag emo expert @artigues05emo
You can private message @EMO or a staff member as well
can you please help
@artigues05emo
@parves.kamal . . . if the update is showing in the app, you should be able to tap the firmware button in settings. You will likely have to update to 2.3.0 first and then 2.3.1.
Try this and let us know how it goes.
EMO doesnt pick up “EMO” most of the time, and its not a mic issue idt
well yeah he doesnt rly respond, i havnt interacted with him in a while tho
Me and my wife just received ours today and we noticed the same. Sometimes it takes me 5+ attempts to get him to hear me. 2 different units.
just realized that if i over exaggerate so it is “EEEEMMOOOOOO” then he picks up every time
there rly needs to be a feature to scan your voice just like ur face tho
Hello, @EMO_And_Kade . . . I have moved your new topic to this thread for this issue.
Is your EMO on the most current firmware 2.7.0? Have you tried turning up the sensitivity in the app under “Preferences”? Is there any competing noise that could distract him?
Also, have you done the wake up training?
If you still cannot get it to work, I advise you contact Support at service@living.ai with a link to a video and his order number or four digit alphanumeric code when he signs into the app.
I currently have the default sensitivity 30/100. I would assume the higher number is more sensitive?
I’ll give the training a go as well.
Edit: I did the wake up training, but I now see it’s not an immediate submission that’s hard programmed into Emo. It’s just another voice used to sample for an update on better voice recognition.
When i say emo he just does his o-ow sound. Does anyone know how to fix it?
have you tried powering off/rebooting
Welcome to the EMO Community Forums, @joymartin . . . I have moved your new topic to this thread for issues with EMO not responding his name.
Please read through here for tips to see if you can get him to respond.
You also may refer to this post:
Yes i have. But thanks for trying to help.
After the word “EMO”, EMO does not respond to voice commands or questions.
