My EMO arrived yesterday and since then I have been trying to connect it to open available WiFi but the App asks for SSID and password. I don’t have a password, it’s publicly available WiFi.
Today I tried it with restricted WiFi but it’s not even identifying the available WiFi connections. What should I do? EMO is not doing anything without the internet. Even it is not telling me the time. instead, it is showing me WiFi connection error.
Its frustrating.
Yup - the requirement for a password for WiFi is a known limitation of EMO at this time. They are aware of it and it’s on the list for resolution in a future update.
In terms of the “restricted wifi” is it running on 2.4Ghz? If not then EMO won’t be able to see it.
As you’ve just received your EMO, take a look at my guide I created. It does cover a fair amount of topics including Wifi and how to connect EMO to your home Wifi or even a portable WIfi modem.
At this time as Wayne as advised. EMO cannot connect to a pubic wifi that does not require a password. You will need to select from the list of available WIFI (SSID)'s and then enter the password for EMO to gain access to the internet.
