Emo movement, forward
Hello all,
with the newest game (treasure hunt)
I noticed that when emo goes forward it leans more to the left. So basically when it should be going forward and moving on a straight line, it just leans more to the left , so when it goes straight for a little longer it makes a circle… very annoying
Does somebody knows how i can fix this?
Does emo has a reset button?
-james-
Emo does have a reset button, but I’m not exactly sure where. The reset button is one of the two holes on the head of Emo (Not the ones at the corners, there are the microphones). But one of them is developer’s only button, so I think you should go to Emo Live’s website and find out there.
Emolives.info
This is the website
But tbh I don’t think reset would fix the problem
