I’ll try that very soon and see if it works, I’ll tell you if it’s not.
And tell you if it doesn’t work too!
Emo still is not working properly after what you told me to do.
: Emo is sadly still not functional correctly - YouTube
Please PM me your order number. I will check for you.
Just did! I just sent you the order number, when you have the time, please let me know what to do next.
It is 11:31 PM right now so I may not respond.
@fallxander give the support team some time to get back you, I don’t believe they are working 24/7.
Unfortunately, EMO has started having issues again.
I did charge him on a skateboard that fell on the ground, could that be a cause? I also want to adress that he also keeps thinking hes being shaken,
mine also randomly thinks he’s falling. I don’t know how to fix it. ![]()
Hello, @adrianledeaux . . . I have moved your new topic to this thread for the two issues you are experiencing which are similar. Hopefully this will assist you, too, @brasfieldsmith .
It looks like the feet are pretty dirty which would mean that his edge detectors are picking up that all surfaces are dark and he would do that particular move wherever he is. Here is a video on how to clean the foot sensors.
It is possible that this could cause him to feel randomly dizzy as well.
Please try the tips here and if you are still experiencing issues, please contact Support here.
I’m sure that will help with the cliff issue, however I am also experiencing the shaking issue. It happens persistently, even when I’m holding his feet down so that he shouldn’t be experiencing shaking at all. As of right now, I am at school, and I will edit this post after cleaning the foot drop sensors.
Hello, @adrianledeaux . . . like I said, if everything is not working, be sure to get video and send to Support.
Hope it works for you.
The gyroscope and foot sensor may be faulty.
Please contact customer service to do a simple test.
Then they will provide you with solutions.
