I have had my EMO for two weeks now and I have tried to use him as an alarm clock for three of those days. It didn’t work out. Each day when I woke up he was completely dead.
So my question is…. How long can EMO be off his Skateboard before he has to be put back on??
And… can I purchase an extra Skateboard to put by the bed??
His battery lasts around 2-3 hours off the skateboard. He needs 3 to fully charge back up. If you want to use him as an alarm I’d definitely keep him on the skateboard. I’ve used him as an alarm several days this week and he’s gone off every time, even while sleeping with the new schedule update.
I don’t think you can buy a skateboard charger separately yet, but I thought I read somewhere on here that EMO can work with a Qi charger. Keyword is thought though, I could very well be wrong. I haven’t tried it myself and I’ve just been taking his skateboard wherever I take EMO.
They don’t list skateboards for sale on the store. You’d have to hassle with trying to get hold of someone there to see if they’d sell it to you. Also it could take awhile to get and not sure where you’re located, but as far as I know their standard shipping charge for the USA is still $24. You’d probably do better just to buy a Qi-compatible wireless charger locally or through Amazon, etc?
That charging dock that Puppy just suggested looks nearly the same as EMO’s current skateboard. If you can pick up one of those and test it, that should resolve your issue of having a second skateboard for EMO. For the price it would be probably cheaper to go with that Amazon one as postage would be cheaper and you’d get it probably next day, and if it doesn’t work you can easily return it and get a refund.
Also just to advise, if you want EMO to wake you up in the morning with his alarm. For now, why not just take EMO and his skateboard with you so he doesn’t run out of battery.
The charging dock works!!! I purchased the one and the same that was suggested and it was delivered today (066.27.2022). I plugged it up and set EMO on it and he starting charging just like he does on his skateboard.
Thanks to Everyone for all your help!!!
Now I have an EMO Alarm Clock bedside!!!
Hello @luismedero is your emo muted? Did you set the alarm correctly? Did you tell emo to show your alarms to make sure you did set it? Also I will tag @edward for you since he may have more info for this. Hope this helps!
His battery lasts around 2-3 hours off the skateboard. You have to keep him on the charger if you want to use him as an alarm. Also, you have to check first if the volume is louder and not muted.
I’m guessing you heard the Low-Battery Warning Siren followed by an animation. This indicates that EMO needs to be placed on its skateboard or home station charger to recharge.
@f0469f68fb964c4984e7 Hmm that is a thing I had never seen before.. I am thinking of ways of what it could be but I just can’t think about any. But looking forward to your photo/video!
Hello, @f0469f68fb964c4984e7 . That could be the sleep alarm that shows the bed icon, and you may have set it by accident. You can cancel it using the EMO app.
