EMO was delivered yesterday. Since EMO is a gift for my daughters b-day i havent unboxed him yet. I have only had a quick look at the light which is included. Now since i have seen this i am a little more concerned because we live in europe. The plug for the light is definetely US and i assume the plug of the charger for emo will also be US. I need a solution for europe 110/230V - 60/50Hz power transformation. Or will just a adapter do the job and the included light / charger can handle 230 V ? Are there any experiences of others?
I’m from Australia, and what I’ve done is picked up a US/China to AU power board to use for EMO’s smart light. It works perfectly well and I’ve not had to worry about any sort of voltage power transformer converter as its not really needed.
Regarding EMO’s USB-C power plug which is also in the China/US format. I’ve simply purchased a better and longer 2meter USB-C cable and plugged that into my power board which also supports direct UBS connections.
This is how I’ve set everything up for both of my EMO’s and I’ve not had any issues what so ever.
I can suggest the following similar kind of power boards and USB-C cables, you can see a link below to Amazon. (this one is a little expensive, but you can find something a little cheaper that will do the job as well.
