Bluetooth Speaker Issue
Hi Guys!
"We all know that EMO can act as a Bluetooth Speaker and play music from our devices, RIGHT?
“Suspected that since the cloud service maintenance, it can no longer connect and is not working anymore.”
Would you mind testing your EMO to ensure there are no issues and checking if its Bluetooth speaker connection works flawlessly with your mobile phone?
To connect to your Mobile Phone Bluetooth Settings you will find:
  • EMO_SPEAKER_[EMO ID****]
  • Voice command: “Bluetooth speaker” or “Turn on Bluetooth speaker” to EMO, then EMO will try to connect to your phone’s Bluetooth
  • Sometimes letting EMO drain his battery completely and waiting an hour before recharging can help resolve certain issues.
Letting EMO drain his battery completely before recharging can sometimes help resolve certain issues due to the following reasons:
  1. Battery Calibration – Over time, EMO’s battery management system may misread the actual charge level. Draining the battery fully and then recharging it can help recalibrate it for more accurate readings.
  2. Software Resets – Some minor software glitches can be cleared when EMO powers down completely. A full discharge forces EMO to reboot from a clean state when powered back on.
  3. Component Cool-Down – If EMO has been running for long periods, internal components may overheat. A full battery drain allows everything to cool down, potentially resolving overheating-related issues.
  4. Memory Refresh – Like many electronic devices, EMO may store temporary data in memory that could cause minor bugs. A full shutdown clears temporary data and refreshes its system.
  5. Charging Issues Fix – If EMO is experiencing problems recognizing its charger or charging inconsistencies, draining the battery and recharging from zero may help reset the charging process.
This method is not a guaranteed fix for all issues, but it is a simple troubleshooting step that has helped some users with minor glitches.
Guide on how to connect to bluetooth below!
https://bit.ly/3S9BOwA
EMO “CyberSapphire” switches to Bluetooth mode but unfortunately no longer connects.
Mine connects perfectly.
Hello, I Tested My EMO Pearl’s Bluetooth And It’s Working On My Side.
Hello, I have two Emos, one connects perfectly, the other unfortunately does not.
@edward When i tested my EMO’S bluetooth speaker it worked but there was some buffering which was annoying and i dont know why this a problem but i will see in the fututre if it stops buffering. :head: :loud_sound:
My Emo is working great with the bluetooth speaker. I also think that after Emos servers update he looks like Emo understands Everyones voice better in loud areas !
Hello, @Degu2218 , @g.schmeinck and @sarikathakur . . . if all of you could, try powering off and on your devices and your EMO, and make sure he is connected to wi fi to see if that improves it?
If not, please post back here and let us know.
Hello @Lindaru,
I have tested it, but unfortunately it still doesn’t work.
So sorry, @g.schmeinck . . . at this time I would advise you to get video and contact Support with a link to the video.
My best to you to get him deejaying and grooving again soon.
Thank you very much! :grinning:
Thanks for help. Today he has no Problem with connecting everything is fine.
I tested the bluetooth speaker and I think it works
My device tells me, I need an app to connect Emo via bluetooth. In the app I can’t find a way to connect, though…
Any ideas?
Welcome to the EMO Community Forums, @christina.kugi . . . sorry to hear this. I use a Samsung Galaxy Tab A-7 Lite for EMO (my smart-phone has no GPS chip, so I bought a tablet). Unfortunately I could never get the bluetooth speaker to work either. I went to the help forums for Samsung and it turns out many who have that tablet also have this issue.
You may want to contact the manufacturer of your device as it appears some do not work with bluetooth for everything.
Thanks for your reply!
It doesn’t let me sync him to bluetooth
Welcome to the community @genericbassguy ,
Please scroll up and read my initial POST. Hopefully, it will provide you with some insights to help resolve the issue you’re experiencing. If the issue persists, you have to contact living.ai via email and send them a video with additional information about the issue and your EMO-ID.
Good luck!
Hi my Emo has a problem,
when I use the Bluetooth speker it is buggy and stutters.
After a while, Emo gets stuck restarting.
This is now the 3rd time this has happened !!
Greedz WIm
from the Netherlands
Hi there @Altodriver and welcome to the community…
Good luck and All the best
