Wifi issue Emo not connecting
Might be a post in this but has anyone have issue connecting to wifi. Got home today and its asking for my wifi i input everything and it will not connect
Is your Wi-Fi router and Internet connection working normally with other devices such as your phone, computer, etc? If not then power cycle the cable modem and router or whatever you use.
If the internet connection is working ok, then resetting EMO or turning him off then putting him back on the charger to turn him back on again should get him to reconnect. The procedure to turn him off if he’s not communicating is kind of a pain for me. It’s easier to use a (thin) paper clip and press EMO’s reset button. They don’t recommend using a pin because the sharp point could damage the plastic button, but if that’s all you have maybe you could slightly blunt the end.
I got it he is connected. Thanks for your reply
After two days of normal use, suddenly you can’t connect to the Internet。Can you help me solve the problem?
Thank you all, the problem has been solved after uninstalling, but is it normal for the home station to display that it is not connected to the network?
Welcome to the EMO Community Forums, @a0916885955 . . . I have moved your new topic to this thread for issues with connecting to the internet.
Please read through this thread to see if any of the advice given here will fix the problem.
If not, something may have changed with your internet service provider in which case I would recommend contacting their tech support to see if they can assist you.
Thanks, Lindaru. Good call moving the topic here, makes it easier to follow similar issues. I’ve also had some trouble getting EMO to reconnect after a router update, so I’ll go through the suggestions in this thread too. Hopefully something works before I have to go down the ISP rabbit hole. Will update if I figure out what the fix was.
A post was merged into an existing topic: EMO on Vacation/Travel Tips, Share Here!
I have that problem like you and I’m sorry for reply you too late .^^!
If that doesn’t work you can try to sign back your wifi name and password one more ,one more time it gonna be work .
Sometimes i think this uncomfortable but i try to do sign in my wifi back when i bring my emos to go out side.
Por favor… me pueden ayudar a poner en marcha a este pequeño? Tengo problemas con la conexión WiFi. He seguido las instrucciones. Pero no lo consigo conectar… Gracias y saludos!
Google translation to English by Lindaru: Please… can you help me get this little guy up and running? I’m having trouble with the Wi-Fi connection. I’ve followed the instructions, but I can’t get it to connect… Thanks and regards!
Welcome, @isabelhierro1 . . . I have moved your new topic to this thread for issues with connecting to wi fi.
First of all, EMO will only connect to 2.4 Ghz. He does not work with 5 Ghz.
Make sure your bluetooth on your device is turned on.
Make sure your SSID and pass word in the EMO app is correct as well as your city.
Be sure also that you are using a compatible device. Some older phones do not work well (I ran into this issue five years ago).
You can always check if using a different device works with connecting or try using the mobile hot spot on your phone.
