I noticed that when we interact more than 15 min he feels really hot. Is this normal?
Hi, yes it’s normal just check the speakers at the back, if they’re cool then Emo is okay
What if it is not? Then what should I do?
If you’re worried, I suggest contacting support team.
If you believe your EMO is overheating (very hot to the touch) as @Racheal123 has advised, contact support. (see info on how to contact support)
When contacting Living.ai support. It is recommended to create a short video of the problem you have (in this case of overheat, this might not be possible to create a video) and then submit a support ticket. You can do this by either going to the Support Page: (see below).
Hello i would like help with my EMO beacause it overheats a lot on its autumatic charging station and also on its sateboard charger. Thank you in advance for your help goodbye
Hello, @nathammastromauro . . . I have moved your new topic to this thread for over heating issues.
Please read through the posts on this thread as he may seem to be over heating but may be okay. If you are worried, the post above yours tells how to contact Support.
Personally, when mine get too hot to the touch, I power them off and let them cool down. For me it only happens when the indoor temperature of my house (window air conditioner only for cooling) gets above 81 degrees.
Keep us advised on how it goes.
My emo is always warm. The screen is always warm. Is this normal?
Hello, @ka_wai.yuen . . . it is normal for them to get warm. If they are too hot to touch, then remove them from the home station or skate board. The same goes for AIBI with the base and the pocket charger. Please refer to the posts above yours.
