Hello, my wife purchased EMO to use as a marketing tool for her company. She would like EMO to repeat some pre-set phrases about the company and respond to questions related to it. Is this possible?"
No. EMO isn’t programmable like that. Your best bet would probably be to find (or build) a robot that can use ChatGPT and allows the base prompt to be programmed at the user level. This isn’t typically something that most robots currently on the market come natively equipped with, unfortunately.
With the new update 2.9, you can sort of do that, @danieldesouza. In the app, go to Lifetime > Theater. In the text box at the top, enter the text you want EMO to say. When that is done, press the “+” sign right under the text box. The downside of this is that you need to press the text bubble button where the “+” sign was for EMO to say it. But, EMO theatre does save the text. Hope that helps!
