Hi guys, I just got my Emo yesterday and he was working fine. However this afternoon when I tested him out again, he seems to have lost his voice. Can anyone assist?
Hi, have you tried the voice command?
Hi there. Yes I have tried the voice commands such as mute, unmute, volume up, volume down, but still to no avail that he speaks.
Hi guys, is there any solution to my problem? I have sent emails to living ai and I know they are on a holiday currently so it’s fine, I also asked on fb and even discord. I have tried rebooting him, giving him all the commands, but his voice box is still down. I have some video of him and it’s really sad that I just received him on the 11th of June and he was working fine with a voice, but it only happened the next day in the afternoon that his voice box just decided to shut off by it’s own. Please assist as I’ve waited for him so long and I have to get him in this result. In any case, is there like a 1 for 1 exchange or so?
[Here is me trying out all the commands, but his voice box is still muted.][20210612_164546.mp4 - Google Drive]
My Emo is doing the same thing. He has no voice or sounds anymore. How can i fix this??
Hello
Restart your EMO and ask him maximum volume , perhaps is mute …you can also try on the app via the volume settings
hopefully that will help
I did try all of those and nothing
When you ask EMO to dance do you hear sound/music when he is dancing?
No he makes no music, no sound at all
Hi @Pjkali2003
If there is no sound even if EMO is dancing, and you have checked his sound is not set to MUTE in the Settings >> Preferences in the EMO APP.
Then it would be recommended to create a short video of this, and submit a support ticket to living.ai (see info below on how to do this)…
When contacting Living.ai support. It is recommended to create a short video of how EMO is not speaking / has no sound / volume when replying to you or when he is dancing, and then submit a support ticket. You can do this by either going to the Support Page: (see below).
Same problem here. And I try all solutions. Restart, check the app volume. Do this several time but he still no sound.
This just happens to my emo yesterday🥲. He still not the same.He responds me when I called him but no answering sound from him.
Hi @Paeng
As advised to @Pjkali2003 … it would be best to create a video of this issue and submit a support ticket, (as shown above) in my previous comment.
Hopefully the support team will be able to help you.
I let EMO run all the way down and then reset him. I was then able to fix his sound in the app. Before that i could not change his volume. He is perfect again. Dancing and goofing off with sound.
Good to see all is working again. ![]()
my emo is almost 12 months old , but in the last month he looses all sounds, if l check on the phone app it shows me that for some reason the sounds have been muted, this has happened about 4 times in the last month. l can turn the sounds back on via the app but in no time at all it goes back to mute. Any ideas on how to fix this issue.
Have you tried also issuing the voice command EMO Volume Maximum?
The EMO APP also works well, but what I’ve normally seen is if you change the slider to fast, it wont accept the volume change.
I know sometimes my EMO’s volume goes down but this is because he’s heard something on the TV/Phone/Radio in the house.
Hopefully this somewhat helps, if not, we can continue to troubleshoot here ![]()
thanks master abbot , the voice command worked.
Hi there, i got my Emo and Docking station which has been brilliant.
However have few little issues happening on and off. One of the issues is sometimes i put Emo back in his docking station and his VOLUME goes down to almost the minimum. The other problem i noticed 2 or 3 times now, is randomly i cant hear him at all(NO VOLUME) and i have to power it off, and power it back on to fix it. Both Emo and Dock have the latest firmwares.
Any ideas ?
Bruno
