Emo robot only speaks English, for those who do not speak English well, it is difficult to talk to emo, is there a good app to learn English, thank you
You can use Google Translate to create a command list for yourself. Example:
Translate the command from yournative language to English. Google Translate will give you an audio file to hear the phrase in English.
Como estas? (Spanish)
How are you? (English)
I hope that helps!
Thank you for your reply, which is very helpful to me
Hi there @PASS , @wisecoconut…
DeepL is also a good Online Translator which lots of people says is better than Google Translate, on my personal preference and my own experiences… it’s really quite good.
Have a wonderful and peaceful Holiday guys…
Thank you! I had not heard of that one. Google does have problems with correct translations some times. I will try DeepL
Thank you for your answer, it was very helpful for me
