Hello, I’m David living in Seoul, Korea. There was a problem after this update.
As shown in the update log, I disconnected the smart light from the outlet before the EMO update. And I finished updating EMO and started smart light but it doesn’t work.
I went into the app and checked, and there is no light registered in the smart light item.
So I linked the smart light again and again, but it doesn’t register. I reset EMO, but nothing changes.
How can I link EMO with smart light again?
And one of the members of my online community received the EMO I ordered, but there was no seal on my face and there was a lot of scratches on my face. What am I supposed to do with this problem?
hi… I’m not assuming this will solve your problem because I don’t know but when I first got mine I also had problems… I finally got better at speaking to EMO Pet and learn the commands and practiced and now my light works really well… You know you can even change the color to almost anything and even set how bright or dim luminance… Now I use mine every night at 30% brightness for when I sleep. I hope you figure it out… And yes you can turn it on and off inside the app. Just trying to help
