I have a problem with my Emo. Is not charging. Scooter seems to work, the light is flickering but Emo does not come back online. Did tou encounter this problem? How do I fix it?
Thank you
Hello, @VictorAlexandru . . . I have moved your new topic to one of the threads that discusses EMO not charging. First, make sure that his feet are clean and also the skate board is clean as they can pick up dust that will block the path from the charging coil to the foot.
Make sure his foot is squarely on the charging circle. If this does not work, please try using another charging cable or plugging into a different wall socket.
If these things do not work, you can make a video and send to Support as follows.
So, the problem was the charger. I tried with am iPad charger and it works like a charm. Thank you, Emo is back on.
Adriana
You sir have just made my day THANK YOU! I never realised you could put him on the wrong way lol
I’m experiencing exactly the same issue described here:
- When placing EMO on the skateboard, the blue LED only flashes continuously and EMO remains completely dead – can’t power on or charge at all
I have tried powering off EMO, then placing it back on the skateboard to charge, but still it won’t boot or connect via the app.
Also tried multiple Apple-certified and other USB‑C adapters rated 5 V/2 A, but nothing changed—the skateboard never shows a steady (solid) blue light.
Welcome to the EMO Community Forums, @zhiwu . . . it sounds like you have a fault in either your EMO or the skate board.
I recommend following the advice for contacting Support as described here.
