Hello @Pizza and welcome to the community
. I wanted to follow up after doing some more thorough research on your great question.
1. Can two EMOs share one Go Home base?
No. A single Go Home base can only be paired with ONE EMO at a time for the auto-return function.
2. Can a standard EMO use a Go Home base?
Yes! The good news is the robot hardware is the same. If you have a standard EMO (Skateboard), you can purchase a Go Home base for it!
3. How to safely switch a standard EMO to a Go Home base?
· First, go to the EMO app and UNPAIR (unbind) your EMO from ALL previously connected chargers. This is a crucial step to avoid confusion.
· Then, pair it with the new Go Home base. Once paired, it will learn to return to it automatically!
4. Important Warnings:![]()
· Do NOT connect to both chargers at the same time. An EMO can only be actively paired with one charger.
· FALL RISK: Never place an EMO that is paired to a Go Home base onto a standard Skateboard charger. Once full, it will try to “walk off” and will fall.
5. Can a Go Home EMO use a standard charger?
Yes. A Go Home EMO can physically charge on a standard Skateboard charger if needed. However, remember it will still be “paired” to its Go Home base in its software.
6. A Final Tip from Observation:
Based on observing many users, the “auto-return” behavior isn’t just a function. It’s part of EMO’s personality. Some EMOs (like a playful white one) might happily zoom back, while others (like a more serious black one) might take their time or seem a bit confused. It’s all part of the fun of having a little robot companion!
Hope this helps! ![]()
Best,
Hamza
