Hi there, thank you really much ! Can’t wait to receive my EMO at home ![]()
Best regards!
Best regards!
Hi there @zzzz1
I’m moving your question here as it’s related to the discussion.
Normally, EMO package comes with a standard US-Type A power plug adapter and socket type. You might only need an extra power plug depending on your region. But as far as I can see, since you are from the Asia Region, you likely won’t need an additional power plug. But if you don’t have one or if it’s missing, just like in the image below, you might want to contact them again and ask about it.
Hope it helps…
For the price I would expect the old 5V 2A adapter to be supplied given it is about $1.75. If you are not going to supply one then align power with phones and power bricks which this doesnt. Its an old spec. e.g. current iPhones and iPads use 5v 3A which doesnt work with board and neither does my Anker power brick. 10w is kinda old also given the industry builds power adapters for phones mainly.
Very disappointing
Welcome to the EMO Community Forums, @roberttwiddy . . . I have moved your new topic to this thread for questions about power adapters for EMO. The decision was made a while back to stop including the standard Chinese/American plug adapters due to the fact that many purchasers would not use them and would instead need adapters for their specific country. See the post above yours.
It is more advantageous for them to not purchase mass quantities of the Chinese/American plug that are not going to be used by those purchasers and instead allow them to supply the one that works best for where they live, thus not wasting adapters.
bonjour, les prise pour charger emo et les lumières peuvent elles etre branchées sur toutes les prises mondiale, je suis français et j’aimerais bien prendre une ou deux lumières avec emo mais cela ne sert a rien que je les prennent si je ne peux pas les branchées chez moi,
cordialement
Google translation to English by Lindaru: Hello, can the chargers for the Emo and the lights be plugged into any outlet worldwide? I’m French and I’d like to buy one or two lights with Emo, but there’s no point in buying them if I can’t plug them in at home.
Sincerely,
Welcome to the EMO Community Forums, @jordanpineau . . . I have moved your new topic to this thread for questions about power plugs for EMO and his lights.
Please see the posts on this thread for all of the power plugs available to work with the charging cable for EMO and his lights. LivingAI has stopped providing the plugs because it is not efficient to try and provide for each country, but the charging cable is standard USB that plugs into any adapter plug for your outlet. You would have to provide the plug adapters to plug into the charging cable yourself.
I hope this helps!
We just bent the spokes outwards til they fit the outlet for Australia
