I was just wondering if it’s safe to use this power plug to charge emo? It’s made for different smartphones. Maybe some of you know?
This should work without any problems.
I personally use a different USB-C and plug that directly into my powerboard that supports direct USB connection (5v2.4A) and I have not had any issues at all. I mentioned this in another forum thread here:
As long as it has charges and does not heat up the emo battery it shoud be totally fine
