I received my Emo today and he can’t charge
Can you help?
make sure he is standing on the skateboard correctly. you will feel it grab like a magnet when you move him around a little and get his left foot aligned with the circle. Emo will then show a picture that tells you he is charging.
To add to what @mandyrose19 has suggested.
When you plug in the USB-C cable that you got with EMO into EMO’s skateboard, be sure to check that it shows for a short time a light blue flash to indicate that power is working on the skateboard, If you don’t see this it could be a problem with the cable or the skateboard, I normally use a different / longer USB-C cable to charge my EMO skateboard, so if you can try using a different USB-C cable to power up EMO’s skateboard, just to check if it’s the charging cable or skateboard might be faulty.
Let us know how you go.
Thank you
but the problem was a flashing skateboard so i try to touch emo foot and the problem solved!!
