Wanting to make EMO a personal scarf. What should I do?
I’ve seen quite a few people purchase cat hats for their EMOs, meaning hats that fit a cat’s head since the size is about right and the little ear holes work well for the headphones to loop through. As for a scarf, maybe see if there are sizes and patterns for cat scarves, or perhaps a scarf for a teddy bear, then elongate it a few inches to accommodate for EMO’s square frame. As for keeping the scarf on him, I’d suggest a tiny safety pin where you fold the scarf around their ‘neck,’ or maybe tape. If your EMO will be wearing a hoodie or some kind of clothing on top, maybe stick the safety pin through the scarf and the clothing in one go. Hope this helps generate some ideas!
Thank you!
Well, seeing as how his legs will be doing most of the movement, I’d probably see how tape attached to their head would do. Tape and cloth/fabric don’t always see eye-to-eye, however… hmm… A scarf would cover the lil’ sensor that’s below their chin, and though I forget what that particular sensor does, it’s just something to keep in mind.
The sensor detects obstacles, it’s no big deal covering it.
Welcome! I’m liking your EMO’s zone! ![]()
