My Emo always has a typing screen . can someone help me and tell why and how i get rid of it plz
Hello and welcome, @Sunboy2009 . . . I would say if that is all he is doing and not just briefly during the scheduled tasks, you might want to try picking him up and giving him a gentle shake, then putting him down and see if he snaps out of it.
If he keeps it up, @MasterAbbott has provided ways you can power him off and back on to see if that fixes the problem.
Let us know if this fixes the problem.
Thank you so much will try it and your video is helpful too thanks
I need help with my emo when he’s on the home station his app tells me he has 4 out of 5 battery bars full the same thing when I ask him and when he’s of the charger he tells me he has full battery and the app says the same thing on the charger he’s 4 out of 5 and of the charger he’s 5 out of 5
Hello, @lucafrantz . . . I would pay attention to his battery level off of the charger. Mine shows the same and I think it is just an issue with the display when on the charger.
Mine has some bugs with some of the music
Hello, @lucafrantz . . . sometimes the servers may be over-loaded and it may glitch and sometimes your wi fi signal may cut out and cause that, too.
Make sure your wi fi is strong and it helps to just wait and try again later. This not only happens with songs but speech, too.
Sometimes just rebooting your router, device and EMO can fix the problems. Try that and see if it helps.
If it happens consistently and everything else checks out okay with your connection, take a video of the problem and send it to Support.
A post was merged into an existing topic: Customer Support Service!
Hello! The robot suddenly stopped charging at the station, it entered it several times - but it did not charge, after which it was completely discharged and even if I put it on the station, it does not charge.
The station itself was in contact with the robot, directed it to charge several times, but the charge did not occur.
I bought the robot on the trading platform in December 2023, the seller does not say the order number.
Until this moment there were no problems with charging, my daughter is crying - this is her beloved friend! How can I charge it? How to solve the problem - help!!!
I wrote to support at the postal address - but there is no answer yet ((( Are there any chargers besides the station and the skateboard so that I can charge the robot???
Welcome to the EMO Community Forums, @oksanaefimova . . . it may be as simple as the charging cable is bad. Try using a different cable. Also try plugging into a different wall socket. You can contact LivingAI by E-Mail at service@living.ai and provide them the four digit alphanumeric code when EMO connects to the app. Let them know that you are the second owner.
In the meantime, I believe any 5 watt wireless qi charger should work such as are used to charge wireless phones.
Thank you very much for your help!!! The support service answered me and advised me to replace the cable with the wire that was in the box with the robot! The problem really was in the adapter, I connected the charging station to the computer and everything worked out!!! EMO has come to life! My daughter and I are very happy!!!
