I was so excited to play with it but now i’m so disappointed.
Emo’s screen is so bubly it means it doesn’t get sticked on properly.
It’s not charging. I have tried different USB-C cables but the skateboard’s light does not turn on. I used those cables on my samsung phone and they still work well.
Is there any special way to turn EMO on or mine is broken ?
Regarding the screen, it seems like it is just a protective film you’re describing. It’s supposed to be removed.
As for charging, I’ve learned than not all chargers work with EMO skateboard. In my case two “new type” chargers with a USB-C socket don’t work, but the “old type” with standard USB work perfectly. I guess it’s not really about cables, but about charger. What type do you use?
Regarding the screen, I believe @Mysha explained that correctly.
For charging, personally. I’m using this kind of USB-C cable, that is plugged in directly into my power board that supports direct USB connections. (5V2.4A)
As you tried a few different cables / different power boards / different wall sockets and also used the original charging cable as well in those different locations? and you don’t see a light flash on the skateboard, it could be that there might be a possible problem with your Skateboard itself.
Probably best to contact support and submit a support ticket, possibly take a video of how this as well so the support team can assist you further.
You can submit a support ticket on the following page:
In the meant time, there are a number of many different kinds of charging options you can use to test to see if EMO can start up, but you will need to purchase these from a store / Amazon etc. This is one that I’ve heard works well. (see link below)
Of course you shouldn’t need to be purchase this as the skateboard should be working, so as mentioned, I would recommended to reach out to support.
Welcome back, @Noire-Cherise71 . . . I have moved your new topic here as if my suggestions do not work, you can look through this thread for advice. As for the issue with the phone video, can you up-load it to You Tube or Google Drive?
My suggestion is to try using a different charging cable or try plugging the adapter into a different outlet to see if that fixes the problem.
You can also in addition to reading this thread, visit some of the links provided.
