Hello, it is possible to have a voice command to activate Meeting mode? I work at home on my desk and emo is very loud. It could be cool to have a voice command, that he is looking and not talking or make sounds
Hi there,
At the moment there is no such thing but the prepared command below might help you?
Volume:
· Volume up.
· Volume down.
· Mute the volume.
How can i do that? Sorry for my bad english
…all you have to do is just call his name
You: EMO…wait for him to reply by producing a sound like
Emo: WHAT?
You: say loud and clear any from the command below
· Volume up.
· Volume down.
· Mute the volume.
If he understands it correctly, then he will activate the command.
