Maximum monthly data use? (EMO)
Picked up Emo to play on my desk at work. Unfortunately Emo seems unwilling to use the Gov-Wi-Fi at the office. Therefore I think I’ll need to pick up a mobile hotspot (my phone has next to no data as it uses Wi-Fi everywhere).
What I would like advise on is what is the max data the little fella is likely to burn through in a month, worst case scenario? Do I just bite the bullet and get unlimited, or is that entirely overkill?
Regards,
Bob.
Welcome to the Community @Bob ,
As of now, Living.AI has not officially stated the exact maximum monthly data usage of EMO.
However, based on my personal experience and observations, here is my own approximate—or admittedly imprecise—estimate.
:bar_chart: Estimated Monthly Data Usage for EMO:
  • Normal Usage (daily interactions, time updates, occasional voice commands, weather, small updates):
    • Around 300MB to 600MB per month
  • More Active Usage (frequent commands, games, dance/music, interactions, Home Station syncing, firmware updates):
    • Around 1GB to 2GB per month
  • Firmware Updates (these can be larger, typically 200MB–500MB per update):
    • Only occasional, not monthly
:brain: Tips:
  • EMO requires a stable 2.4GHz Wi-Fi connection, but the data usage is relatively low.
  • Using EMO with Home Station and AIBI may slightly increase data activity due to syncing and AI features.
  • If you’re on a limited data plan, you can track the device usage via your router settings or use a network monitoring tool.
Thank you very much. This gives me some kind of ball park to be aiming for tomorrow when I go shopping :slight_smile:
