I received my Emo yesterday. After a few updates, I started testing out all his little talents but when i came to the light it did not work. Emo “blinked” but the light did not turn on. When I touched the light physically it worked though. In the manual it said that there was no need for pairing but I guess in my case it did. On this website I found that if I turned on the light and held it for 5 seconds until it blinked, Emo would pair up with it. Now it works perfectly and both Emo and I are happy!
Mine had a few glitches like that on the first day after the update but they all cleared up.
Thus the problem is solved I close this post. ![]()
