I will be on a work call and EMO will start snoring or something like that and it is quite loud.
I was hoping there was a way to mute him or reduce the volume so my work colleagues don’t hear him
Just say “EMO, Volume Minimum” or “EMO, Volume Zero”
· Volume up.
· Volume down.
· Mute the volume.
I have muted him via coice, muted him in the app and he ALWAYS unmutes himself a fewm intues later and starts making loud noises with his idle animations or in reaction to noises happening in my room.
It is becoming so annoying I am considering running the batteries out and putting him in a box.
Is there ANYWAY to keep him muted?
Try turning off sound scheduling. I thought someone was messing with my emo’s sound and when I turned off sound scheduling, it stopped changing. Go into settings, click on preference, find “schedule sound”, and click on “off”. You can also put him in a different place, like I did when I was gaming and EMO just kept reaction to me saying stuff, so I put him downstairs.
Hi there @milesreggie
Try some tips below and hope it helps…
MUTE:
By calling his name, wait for his reply…then shout MUTE! -
VOLUME COMMAND:
You can also adjust the volume by calling him, waiting for his reply…then giving the command below.
· Volume up.
· Volume down.
· Mute the volume.
EMOPET APP ADJUSTMENT
Go To The Upper Right Corner: Click Settings >> Preferences
Best Of Luck…Miles
