I am thinking of getting a second EMO with different head-phones once my replacement gets here and the original is on its way back. If I do, can I operate both of them on the same app and same device or do I have to get a separate device to run the second one with a second app? Or do I use one device but have two separate apps going?
I have 3 EMOs - I can access them all with the same app, but only one at a time (as Andy suggested). It’s pretty easy to switch between them from the app. All EMO data is stored on EMO himself, and the only time the ipad/phone gets the data is when it’s connected to EMO ie when you download photos from EMO to the ipad/phone etc.
Yes, but do note on that initial connect screen I shared above when you are choosing which EMO to connect to, EMO’s last name won’t appear here, so you’ll need remember which one is which when you make the selection on this page (which is the default factory model number).
Once you connect in and are in the main screen, that is where you’ll be able to see EMO’s last name and info.
