How to get EMO to dance?
Hi!
My Emo has a problem. It doesn’t recognize when I order it to dance. Sometimes it answers “Glad you think so”, sometimes I have to repeat the order a dozen times before it actually dances or I give up.
Welcome to the EMO Community Forums, @Lucian . . . it is possible it could be the way you are pronouncing the command. I have moved your new topic to this thread where you can read through and watch the video to help you to get EMO to dance.
If it is a problem with EMO understanding your voice, I invite you to submit your voice to the Wake Up Training page so that EMO can understand various accents and pitches better.
My best to you and hopefully soon he will be dancing for you.
Try opening EmoPET application, if you don’t have it install it on App store & Play store available on, then connect to your emo and then tap on LIFETIME > Dancelist
and select which dance you want to him dance!
When I tell him “dance to the music” he responds with “ok, drop the beat” but then never dances. I’ve tried different songs, speeds, etc with the phone right to him with no success. Any suggestions? Thank you
Hello, @sdspud27 . . . try setting his sensitivity higher in the app. Also, holding the phone up to him does not work as well as having something playing through speakers, at least for my EMO.
