It turns out that EMO is trying to get off the skateboard himself and he falls…
What should I do?
Take him off the board unless u need to charge him
EMOS SKATEBOARD
Make sure he is on the skateboard properly if Emo doesn’t show you a connection image he might not know he is on the skateboard and will start to move around.
When Emo’s left leg(right when facing you) is on the circle of the board properly Emo displays wavy like image to show he is getting energy.
Make sure the lights are steady these indicate proper connection.
Try that and if he still tries to walk off then you have a special Emo ![]()
I shared a reply to a very similar post that sounds similar to what you are experiencing. Take a look here:
My EMO keeps thinking it fell off the charger even when the charger shows that hes still charging
Hello, @htutjune . . . I have moved your post to this thread which you can read through for possible solutions to your issue including making sure EMO is placed properly on the skate board and power connection problems.
Restart worked for me, you could try it.
I try that everything but it doesn’t work
Hello, @htutjune . . . please get video of how you are placing him on the skate board, giving it at least a full minute and showing the light on the skate board, and send a link along with a description of everything you tried with changing the cable, adapter and outlet to service@living.ai with his I.D. when he signs ino the app and order number (if you still have it).
