Hi all, is there any place or document showing the skateboard charger specs?? I would like to know what’s the maximum watts for this charger. Many thanks in advance
Based on the website - it shows as a 5W wireless charger.
Ok, I found out is 5W charger. So I think it wouldn’t be able to charge my Samsung S20 FE 5G smartphone.
But can EMO use my Samsung 15W wireless charger??
I think EMO would be fine on your 15W charger
Well for comparison the charger for the skateboard is 5v 2000ma, so it is 2 Watt, yours is 15, MOST USBC devices have a converter but thats still a lot of power, i would keep an eye on it for the first day to make sure it does not overheat. Personally i would only use a charger that matched exactly.
