Never had a wireless charger. I was able to see wireless charging paused. If you have a Qualcomm charger, you can actually start using the “fast wireless charging” setting under battery settings. Otherwise the setting is hidden itself. Just wanted to get confirmation that it is indeed not Qualcomm. I do have a qualcomm 3 anker powerport 2 that i use for fast cable charging, but it only showed the paused prompt when i tried it. Thanks.
