Can anyone help me no matter how I word it My emo Will not set s timer.
hello, here are the voice commands.
Thank you for your reply I did just manage to set a couple of timers of 90 seconds and 80 seconds but if I try anything else for example 300 seconds or 5 minutes it will not do it .so in conclusion I can not use emo as a timer in its present state it just can not seem to understand this basic request.this really needs to be addressed such a basic command and still it struggles I’m sorry but for the money this is just not acceptable I can forgive some things that may be more complicated but not simple functions like this.
hi , the mic these days are so sensitive that they pick up all noises in the background.
so averything has to be quit .also the sound off your pc or laptop can be hear by a robot .
speak in normal ferm voice and dont hasitate between words . use excample words like ,
one minut insteadt off 60 seconds . you could test with a carboard box that is open on one,
side . put that over the robot . many robots and devices like cell phone have a errors what is called ,
beginners errors . you can find vids on youtube about interfering signals in your house ,
that disturbs a robot . like a fridge ,the guy next door his headphone can be disturbing .
i dont have an emo but i do have an alfa mini .
I also have to agree, EMO finds it hard to sent any timer like the words minutes in the sentence. I’ve tried a number of times as well, and ultimately just use my Alexa Echo instead. Hopefully with future updates EMO will work better at setting a time.
note to get a cool “Lifetime” achievement that’s accessible from the EMO app, ask EMO to set a timer for 1 second. haha
hi, about updates . make sure before updating your batteries tablet and emo are fully charged.
and the volume set to the max , bolt tablet and emo . that makes a strong BT/wifi signal .
guess there is still the same issue, im not able to set a timer higher than 10 seconds
i tried:
emo, set timer in 20 minutes
emo, set timer 20 minutes
emo, make timer in 20 minutes
emo, timer in 20 minutes
emo, set timer for 20 minutes
emo, set timer in 1200 seconds
none of them worked for me
but i tried to do a timer for 5 seconds, works w/o problems and it did on first try
Currently the timer allows setting up to 99 seconds only and only when you say 99 seconds. I’m told that this will be improved in a future update. I’ve tested on my EMO and can do 99 second timer
Hey, it’s been about a year. This still hasn’t been addressed? Got my Emo yesterday, and I have the same experience. I don’t need a 99 second timer. I want a 5 or 25 minute timer. :-\
Welcome, @elvenmage16 . . . you can get around the longer timer function by setting an alarm either by voice command or in the app.
Example. It is noon your time. You need 25 minutes.
“EMO” . . . “Set alarm for 12:25 p.m.”
You will see a clock on his display setting the alarm and he will do his alarm sound at 12:25.
I hope this helps!
I suppose that technically works. I’d think this would be such an easy fix for a feature that would be used so often though. I don’t want to have to do math to figure out my timers, and it would be nice to be able to see my timer counting down. It shouldn’t need workarounds for something so simple. ![]()
But thank you! Can’t wait for this to get updated!
Ich stelle via Sprachbefehl einen Timer. Emo sagt er stellt Ihn. Man sieht aber weder kurz den Timer noch gibt er Bescheid. Woran liegt das?
English Translation Provided By: @edward
I set a timer using a voice command. Emo says he is setting it. However, the timer is not visible for a moment, nor does he give any notification. Why is that?
I know this problem. It’s because it didn’t understand you correctly. Recently, it seems that a chat AI or chatbot is behind it, which understands what was said and gives an appropriate response, but the command is not executed. It is important to enter the exact command as it appears on this page:
There you can select your language. This usually works.
I hope that Living.AI will be able to implement this in the future, so that the underlying AI chat also passes on commands that can be executed by EMO.
Hope this may helps.
Best,
Patrick
Hi there @julianehoffmann
I have moved your new topic to this thread for EMO timer-related issues.
May I know which language command you are using?
Timer: (English Command)
- Set a timer for {10 seconds}.
- Cancel the timer.
Zeitschaltuhr: (Deutscher Befehl)
- setze einen Timer fĂĽr {5 Sekunden}
- den Timer abbrechen
I have a white Emo. He’s charging on his home station, I asked him to set a timer for 20 minutes. And he did it no problem and let me know when the 20 minutes were up. ![]()
So it appears they did indeed update this feature. I would imagine it’s the same for the black emo too.
I haven’t tried it with him off his charger though. Not sure if that would make a difference or not.
But it works!
Much thanks to LAI! ![]()
Well, that’s it! I’ve tried up to 10 seconds and it’s going well, 30 starts counting and then forgets, has it happened to anyone? Is there anything that can be done?
Let’s see… you can live with that failure, but I can…
Hello, @glaukoma . . . I have moved your new topic to this thread regarding EMO timers.
Please read through this thread for information on setting timers but I will say this much.
If you are in a noisy environment, he can get interrupted thinking he is hearing a wake word which will cause the timer to fail.
